Thread: 2008 Grand Prix right abs wiring harness replacement
Results 1 to 5 of 5
  1. #1 2008 Grand Prix right abs wiring harness replacement
    Nov 2013
    pittsfield ma. 01201
    I have a bad abs wire harness on the right front wheel could use some help on replacing this. Should I replace the entire harness up to the abs module any tips on doing this would be helpful thanks for any help.
  2. #2 Re: 2008 Grand Prix right abs wiring harness replacement
    St. Louis
    Where is it bad at? The plug at the hub side? Usually you can just cut it back enough to get clean wire, then soldier/heat shrink the connection and be good to go.
  3. #3 Re: 2008 Grand Prix right abs wiring harness replacement
    GTP Level Member
    Oct 2014
    Most breaks are in the first 9 inches of the plug. So go back a ways to where you can get a decent splice installed
  4. #4 Re: 2008 Grand Prix right abs wiring harness replacement
    Nov 2013
    Not sure where short is hub wires are ok. If I move any wires after that abs lights come on.
  5. #5 Re: 2008 Grand Prix right abs wiring harness replacement
    Nov 2013
    Sounds good if I touch wires in that area the abs lights come on. thanks for your help
  1. Grand prix door replacement wiring harness issues!
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 06-14-2014, 09:46 AM
  2. Grand Prix HUD Wiring Harness
    By MattF in forum General Tech Discussion
    Last Post: 02-14-2013, 03:51 PM
  3. 98 grand prix se wiring harness
    By rmplow in forum General Grand Prix Discussion
    Last Post: 04-13-2012, 12:53 PM
