Thread: Jack points
Results 1 to 9 of 9
  1. #1 Jack points
    SE Level Member Felix's Avatar
    Jul 2016
    Quick question, trying to lift the front end of an 02 Grand prix but cant use the pinch welds, anywhere else I can safely jack it up/place jackstands?
  2. #2 Re: Jack points
    floor jack, dead center of the front of the sub frame, jack and max the jack out, then you can put the jack stands under the sub frame.
  3. #3 Re: Jack points
    Jul 2016
    Thanks a lot!
  4. #4 Re: Jack points
    Omaha, NE
    Second (less safe option). Only use this if you're in a real bind... If you have an engine hoist, you can tie a chain around the motor mounts and use the hoist to lift the front end up.
  5. #5 Re: Jack points
    no way id hang the whole car by the engine, trusting motor mounts only is stupid silly.
  6. #6 Re: Jack points
    Omaha, NE
    You sir are not as redneck as I are.
  7. #7 Re: Jack points
    Apr 2012
    Bancroft. Ontario, Canada
    chuck the jack anywhere under the car, and jst start crankin??
  8. #8 Re: Jack points
    Or just slide the jack further in and use the unibody frame like I always do.
  9. #9 Re: Jack points
    Aug 2016
    S.F. Bay Area (east bay), California
    I always use the rearmost subframe supports. Slide the jack in behind the wheel so the handle can crank up and down just behind the wheel in the wheel well. Then slide a jackstand just in front of that on the subframe.
  1. This is why you use an extra jack or jack stand.
    By Taz Magister in forum Off Topic Discussion
    Last Post: 06-25-2011, 10:48 PM
  2. Rusted out jack points
    By sjp 2002 GT in forum Brakes/Suspension/Chassis
    Last Post: 12-01-2010, 04:26 AM
  3. Jack Stand Points
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-08-2010, 01:16 AM
