Thread: Temp problem
Results 1 to 4 of 4
  1. #1 Temp problem
    Jul 2016
    colorado
    1995 3.1 aux fan not comming on.temp reached 250. ok on highway about 190.has anybody seen same and what did you do. Thanks
  2. #2 Re: Temp problem
    Check fuses and maybe swap a relay or apply power straight to the fan to make sure it still works.
    If you have having temps rise that high and fast when you aren't moving you have a coolant flow problem or similar. Perhaps the thermostat isn't working correctly or maybe even the water pump fins aren't pushing coolant quick enough. The other possible thing is the radiator is partly plugged and can't let coolant move.
  3. #3 Re: Temp problem
    Aug 2016
    Norfolk, VA
    I've had similar problems in several vehicles. In my old 1500 the previous owner had filled the radiator with stop leak, which caked up the t-stat and stopped the coolant. Pulled the t-stat and she was good to go. I eventually replaced the radiator and performed a full flush before dropping a new thermostat in, otherwise it would just clog again. Check your radiator hoses. They both should be warm/hot. If one is MUCH cooler than the other, that is an indicator of a clog.
  4. #4 Re: Temp problem
    Jul 2016
    colorado
    Thanks for the reply. After research i found out that the 3100 run hot 190 to 230 this was a design for emsions. The aux fan dosnt come on till ac is in use or temp gets critical.
  1. Temp gauge problem after coolant temp sensor change.
    By Beast388 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-02-2015, 08:00 PM
  2. temp gauge problem
    By 98DaytonaGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-16-2015, 01:12 AM
  3. Engine Temp Problem....Cant figure it out
    By pshabou in forum General Tech Discussion
    Last Post: 02-06-2013, 02:12 AM
  4. Temp sensor problem
    By keadams in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-17-2012, 01:29 PM
  5. temp gauge/big changes problem
    By manymarius73 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-10-2012, 11:33 PM
