Thread: Hey Guys
Results 1 to 8 of 8
  1. #1 Hey Guys
    Aug 2016
    Omaha
    New to the group. I live in Omaha, NE. My wife's 2006 Pontiac Grand Prix has a weird issue. The right side turn indicator blinks fast and then we could hit a bump and it works normally. I replaced the bulb and still had the issue. Would shake the wires and it would start working. Traced it out it appears to be this thick black wire with yellow hash marks on it. It has three black wires connected on either end. Is this something I can just cut out and bypass or do I need to put something there. I am just afraid it is a resistor or something. Car did get dunked but we replaced the engine and this appeared several months later. If you need a picture I can get you one later.
  2. #2 Re: Hey Guys
    if its a factory taped up splice open it up and look for corrosion. if you find any you need to cut that splice out and re solder it back together.
  3. #3 Re: Hey Guys
    Aug 2016
    Omaha
    Already pulled the tape. Let me add a picture to better explain
  4. #4 Re: Hey Guys
    Aug 2016
    Omaha
    Hey Guys Attached Images
  5. #5 Re: Hey Guys
    Aug 2016
    Omaha
    I think you can see why I am asking instead of just splicing it.
  6. #6 Re: Hey Guys
    the fat black loom with 2 or 3 black wires inside? id cut that open.
  7. #7 Re: Hey Guys
    Aug 2016
    Omaha
    ok thanks. I will do that and see what happens I guess.
  8. #8 Re: Hey Guys
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    It sounds like somebody tried to use LED bulbs, with resistors spliced in.
    Resistors probably broke, which is why it flashes until you hit a bump. If there are resistors in there, I would cut them out, solder each wire back together, and get some cheap regular bulbs, unless you want to try and keep the LEDs.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  1. Hey guys, help please!!!
    By CapitalJJ in forum Introductions/Noob Questions
    Last Post: 05-13-2012, 12:35 PM
  2. FL guys
    By Sandman in forum Southeast
    Last Post: 10-12-2009, 07:01 PM
  3. Hello guys
    By speed in forum Introductions/Noob Questions
    Last Post: 09-23-2009, 02:14 PM
  4. Please help me guys
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-05-2009, 09:35 AM
  5. attn: guys who are car salesman or guys who know them
    By shaferz in forum Off Topic Discussion
    Last Post: 03-25-2008, 05:05 PM
