Thread: Hey. new gxp owner here. Need some help with mufflers !!
Results 1 to 7 of 7
  1. #1 Hey. new gxp owner here. Need some help with mufflers !!
    Jul 2016
    Maryland
    Just got a 06 GP GXP...
    Failed Md inspection because the mufflers have holes starting in them
    Question.. where can I get just the mufflers without buying the whole darn exhaust system ??? TIA
  2. #2 Re: Hey. new gxp owner here. Need some help with mufflers !!
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    I think I found the stockers on Summit. No idea the part number, but I remember they were walkers (brand). You won't need a whole cat-back or anything.
    I had the exhaust stuff written down, but I found it searching this site. They're 2 1/4" offset inlet, center out I believe. Call a local shop to make sure.
  3. #3 Re: Hey. new gxp owner here. Need some help with mufflers !!
    Jul 2016
    Maryland
    Searched Walkers site..no listing for 5.3L ???
    Called 2 local shops and was told same thing, nothing showing for the 5.3 without the whole cat-back
  4. #4 Re: Hey. new gxp owner here. Need some help with mufflers !!
    Find ones the same length and same inlet/outlet as stock and buy those.
    They will have to be welded in because the cat-back system are all one piece.
  5. #5 Re: Hey. new gxp owner here. Need some help with mufflers !!
    Dec 2013
    Enfield
    Why not just use some muffler tape for the time being to get thru, go to another location if need be. there are no real direct bot on beside Walker, and even those require work. check this thread.
    http://ls1tech.com/forums/ls4-perfor...ust-today.html
  6. #6 Re: Hey. new gxp owner here. Need some help with mufflers !!
    Just buy some cheap 3800 mufflers.
    They're basically the same damn thing.
    Use them.
  7. #7 Re: Hey. new gxp owner here. Need some help with mufflers !!
    Donating Users
    Jul 2016
    Youngstown Ohio
    I have a 06 GXP same problem, no mufflers listed. Look up same year 3.8 mufflers work, hangers are same inlet same just cut behind old muffler, have to get your tips welded on.
  1. What mufflers should i buy?
    By suitercrew in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2015, 09:50 AM
  2. New Mufflers?
    By gtpeddie in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-25-2012, 04:41 PM
  3. slp mufflers
    By 2005GrandPrix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-19-2011, 12:34 AM
  4. mufflers?
    By danielle15 in forum General Tech Discussion
    Last Post: 03-06-2011, 10:33 PM
  5. new mufflers
    By cjim in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-07-2010, 04:09 PM
