Thread: Help... .05-1.5 kr on wot
Results 1 to 10 of 10
  1. #1 Help... .05-1.5 kr on wot
    SE Level Member 40thAnnGTP2002's Avatar
    May 2015
    high point nc
    I have a 2002 Gtp and mods are headers-hi flow 3" cat-drilled tstat 180°-open cone intake-lucas 42.5 injectors-3.4 press on pulley-zzp pcm tune- autolite 104-ac delco factory wires... I am showing from 0.5-1.5 kr on full throttle....How do I get rid of my kr???
  2. #2 Re: Help... .05-1.5 kr on wot
    Custom tune to fine tune the car, reduce timing etc.
    Or remove the pulley.
    If it was me, anything between 0-1kr isnt even something to bat an eye at.
  3. #3 Re: Help... .05-1.5 kr on wot
    May 2015
    high point nc
    OK thank u for the advice. I'm still learning about kr and I like the pulley but idk too much about fine tuning. I want to learn tho.
  4. #4 Re: Help... .05-1.5 kr on wot
    May 2015
    high point nc
    Would a short stack I/c be of any help to me?
  5. #5 Re: Help... .05-1.5 kr on wot
    Maybe.
    But a bigger pulley is way way cheaper. And in the end if you went with a intercooler, there could be so much more on the table to gain with it but that ZZP tune will do nothing for it.
  6. #6 Re: Help... .05-1.5 kr on wot
    May 2015
    high point nc
    True but I/c is on my list and since its not but 1.5 kr max Im just going to run like this until I save up for the short stack I/c. Afterwards I'll get a finer tune.
  7. #7 Re: Help... .05-1.5 kr on wot
    Kemmerer, Wyoming
    a bigger pulley will be more beneficial in the long run because the tuner will increase the timing advance which will make more power
  8. #8 Re: Help... .05-1.5 kr on wot
    SSIC is not worth it.. Go FSIC
    04 Comp G.
  9. #9 Re: Help... .05-1.5 kr on wot
    May 2015
    high point nc
    OK thank u for the info. How hard is the install for a fsic?
  10. #10 Re: Help... .05-1.5 kr on wot
    http://www.grandprixforums.net/threa...BS-Intercooler
    04 Comp G.
