Thread: Both heater hoses are cold. Radiator hoses are hot though
Results 1 to 6 of 6
  1. #1 Both heater hoses are cold. Radiator hoses are hot though
    May 2015
    Joliet, Illinois 60436
    Okay guys, so my uncles heat is cold as ice. He's driving a 02 Le Sabre. So I go take a look at it and the only visible problems I saw are that his coolant elbows are leaking a little bit, that's no problem easy peezy. So we have the car on for about 15 minutes with the heat blasting on full and I go and feel the heater hoses and they're are stone cold, but the radiator hoses are hot. I take a look at his coolant and it's at the right level but it's as murky as pond water. So I ask what's he been putting in the coolant and he whips out dollar store green coolant. So fellas, is this a case of a clogged heater core or heater hoses? Is a coolant flush the most logical solution, along with replacing coolant elbows and tstat?
  2. #2 Re: Both heater hoses are cold. Radiator hoses are hot though
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by snj111795 View Post
    Sounds like the DEX-COOL and green coolant mixed and clogged up the heater core. You need to get that car flushed ASAP so more passages don't get clogged up. This could turn bad soon. And fill it up with green coolant after you completely flush the system.
  3. #3 Re: Both heater hoses are cold. Radiator hoses are hot though
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    I would flush it.
  4. #4 Re: Both heater hoses are cold. Radiator hoses are hot though
    cores air bound, flush it and leave its hoses full of water, put em back on, heat will then work fine. the leaking elbows may have helped air get in the core.
  5. #5 Re: Both heater hoses are cold. Radiator hoses are hot though
    May 2015
    Thanks everyone! We just went and picked up some aluminum elbows and new tstat and fluid. We're gonna work on it sometime next in the next couple of days. I'm sure if we run into any problems you'll hear from me again! Again thanks everyone who reached out
  6. #6 Re: Both heater hoses are cold. Radiator hoses are hot though
    Apr 2015
    I hope you bought green coolant. DEX-COOL is worthless and will only give you problems in the future. Filling your system up with conventional green coolant (ONLY AFTER YOU DID A COMPLETE FLUSH) will be much better to maintain and not worry about.
  1. Where can i get Colored Radiator Hoses?
    By DrSnazzy in forum Visual/Body Modifications
    Last Post: 07-27-2013, 07:31 AM
  2. Radiator Hoses Collapsing
    By Chadgervais in forum General Tech Discussion
    Last Post: 10-01-2012, 08:09 AM
  3. Should I replace the Radiator Cooling hoses?
    By andremike in forum General Tech Discussion
    Last Post: 02-21-2012, 08:05 PM
  4. Collapsing radiator hoses
    By b3gtp in forum General Tech Discussion
    Last Post: 04-03-2011, 05:59 PM
  5. Heater core hoses? Which are which?
    By m0ng00se in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-19-2008, 10:33 PM
