Thread: Cranks but won't start!! help!!
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
  1. #21 Re: Cranks but won't start!! help!!
    GXP Level Member
    Mar 2015
    Tomball
    Let me go look I Have it out back in the shop. PM me if you want.
    Jeff
  2. #22 Re: Cranks but won't start!! help!!
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I feel it would make your life waaay easier if you just got a fuel pressure gauge and put it on the fuel rail. Sure you can push down the valve to see if it squirts but I think it's worth having some real numbers to go with.
    I think HighOctaneRacing is on the right track, I had an airtex fuel pump on my GTP that was awful... the check valve in it was no good from day 1, after it would prime the fuel would run right back to the tank. I had to start the car while the pump was still priming. Replaced it with a Delco OEM replacement, and everything was fine.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  1. Cranks but no start
    By 3rdgen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2014, 09:34 AM
  2. cranks no start
    By GTPSHAWTY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2014, 06:09 PM
  3. Cranks but won't start
    By Thompsju in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-25-2013, 03:41 PM
  4. Car Won't Start... Just Cranks.
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2010, 10:23 PM
  5. Cranks over but will not start
    By wfj8251 in forum General Tech Discussion
    Last Post: 02-08-2009, 02:47 PM
