Yeah. That will work. James pointed out a good detail. The 97-98 brackets have the coolant elbow as part of the bracket. So of it breaks it can not only ruin your bracket but also your timing cover.
i had to switch to a early model bracket / tensioner setup to use my older alternator. I also picked the camaro set up. Only issue I have not fixed yet is the heater hose couplers. I will be making a "L" shaped bracket to hold them in place.
That's what I did. Wasn't that hard:
I also mentioned the 99 Camaro bracket in the OP, and I showed what the other bracket breaks if used.
