Thread: crank bolt problems
Results 1 to 6 of 6
  1. #1 crank bolt problems
    Mar 2015
    Western North Carolina
    Hey guys me an my buddy are dropping a cam in to his 97 gtp an I've done this b4 with my car but we hadn't had never the problems with my car than we have with his can u guys help give me any ideas how we can get his crank bolt off we've hit it with an air inpact gun an nothing we've heated it up an use a giant breaker bar an nothing then we heated it up an hit it with the inpact gun again an nothing. If we get a breaker bar on it an get the bar on the ground or on the frame some how can I jump the starter an get the motor to spin it off its self I was gonna try this but I didn't kno if the bolt treads the same way the motor would turn so I wanted to ask you guys your opinions thanks for any advice
  2. #2 Re: crank bolt problems
    Dec 2012
    Where 4T65E's were born
    The starter trick works on these cars. Regular threads and the crank spins clockwise
    Sold.
  3. #3 Re: crank bolt problems
    Mar 2015
    thank you 02 navyblue I wasn't sure an I didn't wanna have to o him a crank or a block lol thanks again
  4. #4 Re: crank bolt problems
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    http://www.grandprixforums.net/threa...***-Crank-bolt
    Check this out. Me earlier this month trying to get it off. the last post is a video of me getting it off. Starter trick works great..
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  5. #5 Re: crank bolt problems
    GXP Level Member
    Mar 2015
    Tomball
    IF it doesn't work the first couple of times put your battery on the charger for a little while (or use the jump feature if you have one). That was the ONLY way I could get my crank bolt loose.
    Jeff
  6. #6 Re: crank bolt problems
    Sometimes...the bolt does fight.
    Don't take it as a sign that your manliness is in question. It's fun to bust on buddies if they are helping though.
  1. Mother******* Crank bolt
    By chrsmi1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2015, 08:40 PM
  2. How many times can a crank bolt be re used?
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2012, 06:26 AM
  3. 24 mm bolt on crank?
    By legend in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2012, 05:01 AM
  4. Crank Bolt Will Not Come off
    By BoilerTom in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2012, 08:03 AM
  5. problems removing crank bolt from hub
    By BonesSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2010, 07:50 PM
