Thread: How to replace a water pump (3.8L)
Results 1 to 19 of 19
BillBoost37 How to replace a water pump... 12-10-2014, 08:18 AM
Sven the Sexman Re: How to replace a water... 12-10-2014, 08:19 AM
jimzssei Re: How to replace a water... 12-10-2014, 08:25 AM
HighOctaneRacing Re: How to replace a water... 12-10-2014, 08:26 AM
BillBoost37 Re: How to replace a water... 12-10-2014, 09:17 AM
Below Average Joe Re: How to replace a water... 12-10-2014, 09:39 AM
Scottydoggs Re: How to replace a water... 12-10-2014, 10:26 AM
BillBoost37 Re: How to replace a water... 12-10-2014, 10:36 AM
Scottydoggs Re: How to replace a water... 12-10-2014, 10:40 AM
BillBoost37 Re: How to replace a water... 12-10-2014, 10:55 AM
Scottydoggs Re: How to replace a water... 12-10-2014, 11:11 AM
stocker Re: How to replace a water... 12-10-2014, 04:20 PM
aligater Re: How to replace a water... 12-11-2014, 08:41 PM
DanPrixGTP Re: How to replace a water... 12-11-2014, 08:50 PM
FordMan77 Re: How to replace a water... 12-13-2014, 07:56 PM
HighOctaneRacing Re: How to replace a water... 12-13-2014, 09:02 PM
newmans1985 Re: How to replace a water... 12-19-2014, 01:34 AM
Scottydoggs Re: How to replace a water... 12-19-2014, 08:34 AM
Below Average Joe Re: How to replace a water... 12-19-2014, 08:50 AM
  1. #1 How to replace a water pump (3.8L)
    Here's the BillBoost method for beginners.
    * Items that can be skipped, however doing these will give you tons of room. This is good for first timers or those that are not yet fully comfortable working in tighter areas.
    1. Disconnect negative battery cable
    2. Drain coolant
    3. Remove two 10mm quick nuts holding the overflow tank if it's on the strut tower (99+), lay it on radiator support.
    4. Remove belt(s) (15mm)
    5*. Unbolt alternator and lay back on engine (no need to disconnect electrical)
    6*. Remove 3 bolts (either 13mm or 15mm) holding alt tensioner bracket onto motor and wiggle carefully to not hurt the coolant elbows. Lay on cowl if you leave the hoses attached.
    7*. If NA, remove two 15mm bolts/nuts and lay coils/icm bracket on front of motor.
    8. Going through the ps pump pulley at 12 o'clock and 6 o'clock remove the 2 13mm bolts. I leave them in the pump and lower it down to let it rest on the trans.
    9. Remove the 4 8mm bolts on the waterpump pulley. You can either loosen them slightly when the belt is on, or you can use a screwdriver positioned like the picture to hold the pulley while you break all the bolts free, then remove them all.
    10. Remove the 4 13mm bolts and 4 10mm bolts holding the water pump. Tap gently to free it up.
    11. Clean the gasket surface.
    12. The new gasket and pump should now be bolted in place. The manual does not suggest RTV and I do not either. However some decide to use it. If you do, use it very sparingly and remember if you ever have to do another water pump, you'll have to clean that off as well.
    13. Torque the bolts as follows:
    13mm bolts: 13 ft lbs
    10mm bolts: 10 ft lbs
    14. Reinstall pulley for ps pump
    15. Reinstall PS pump. I find that putting the socket on the upper bolt and looking straight down, you can see the hole and line it up easy. Then I ensure the lower bolt is not sticking out the back of the pump and wiggle the bottom of the pump toward the crank pulley, with a socket on the lower bolt, you'll feel it find the hole and presto, easy ps pump.
    16. Alt tensioner bracket, Alt, coil pack and coolant overflow get reinstalled.
  2. #2 Re: How to replace a water pump (3.8L)
    GrandPrix Junkie
    Mar 2012
    NC
  3. #3 Re: How to replace a water pump (3.8L)
    SE Level Member jimzssei's Avatar
    Sep 2014
    Subscribed for a great write up :thumbup:
  4. #4 Re: How to replace a water pump (3.8L)
    Enfield, CT
    I'm surprised a write-up was made available considering there's nothing hard or special about doing a water pump on a 3.8 lol
  5. #5 Re: How to replace a water pump (3.8L)
    People that haven't done a lot of work can benefit from some pictures and order of operations.
    Notice how I didn't start out with, remove radiator cap and throw across street into farmers field.
  6. #6 Re: How to replace a water pump (3.8L)
    Aug 2011
    'Merica
    Thanks Bill.
  7. #7 Re: How to replace a water pump (3.8L)
    only thing i dont see listed is if supercharged you need to take the sc belt idler pulley off. its a t55 or 15 mm on some cars.
    unless i just flat out failed to see it. you know how i read these days.......
  8. #8 Re: How to replace a water pump (3.8L)
    Nope..you nailed it Scott.... unless you just sneak on past it like I do.
    I've also put a round cut into it. That way it's not in the way.
  9. #9 Re: How to replace a water pump (3.8L)
    i just take the pulley off, not its pedestal.
  10. #10 Re: How to replace a water pump (3.8L)
    Ped is still in the way
  11. #11 Re: How to replace a water pump (3.8L)
    not if you do like you said and wiggle it past the lip there. mine came out, will little to no effort. other then the surprise 6 block walk for a t55 socket lol
  12. #12 Re: How to replace a water pump (3.8L)
    GTP Level Member
    Aug 2012
    st louis park, MN
    Please stop helping people with your well-thought-out and detailed write-ups.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  13. #13 Re: How to replace a water pump (3.8L)
    GT Level Member aligater's Avatar
    london ontario canada
    No thread sealant on the 13 mm pump bolt threads?
  14. #14 Re: How to replace a water pump (3.8L)
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    I just did a water pump and power steering pump on my car two days ago.
    Scotty is right, for S/C cars, you need to remove the idler pulley (T55, I think) but the pedestal is "not" in the way. Makes things a bit more difficult, but you can sneak past it with a little wiggling and trying to tilt the bolt away from it.
    - As a side note, I used NO RTV/Silicone on any of the water pump bolts, nor on the water pump gasket/gasket surface. (Now-a-days, a new water pump comes with a metal gasket, pretty nifty). I only use Copper RTV on the coolant elbows.
  15. #15 Re: How to replace a water pump (3.8L)
    GrandPrix Junkie
    St. Louis
    Great writeup Bill. I have a question on step 8. Do you recommend remove/disconnect the rear knock sensor wire from the PS pump before resting it on the trans? Not sure how much slack is in that wire and don't want to rip it out.
    And funny you mention the "remove cap and throw across street into farmers field" because that is exactly what is across the street from me. I have "placed" some items in said field in the past, lol... I'm all better now tho
  16. #16 Re: How to replace a water pump (3.8L)
    Enfield, CT
    ^^^hahahahahah^^^
  17. #17 Re: How to replace a water pump (3.8L)
    Oct 2014
    United States
    I was wondering if you could help me. I just changed the water pump on my 06 and ever since then it seems like the heater isn't working like it should. I have my heater set at 90 since it's been pretty cold outside but it doesn't feel hot enough in the car.
  18. #18 Re: How to replace a water pump (3.8L)
    you have air in the heater core. take both hoses off the alt bracket, then flush one hose with a garden hose. put the hoses back on and enjoy the heat.
  19. #19 Re: How to replace a water pump (3.8L)
    Aug 2011
    'Merica
    It took my GP over an hour to bleed air out of the system.......Bill helped ease my frustration.
  1. Replies: 5
    Last Post: 06-22-2014, 07:32 AM
  2. How to replace heater core and water pump
    By dgjks6 in forum How To Write-Ups/Tech Tips
    Last Post: 08-22-2013, 07:29 PM
  3. Bad water pump,wrong water pump? 2002 GTP
    By R STARR in forum Introductions/Noob Questions
    Last Post: 06-03-2013, 06:47 AM
  4. Water pump
    By robblk04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-01-2011, 03:18 PM
  5. Water Pump
    By carl06GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 07:58 AM
