would buying a "canned" tune for e85 be okay if on just a 3.4 set up? And then drop pulley sizes accordingly? Other than that all you'd have to get injectors right?
Yeah I told them all they were ****ing retarded.
Sent from my Galaxy Far Far Away
I'm running a 40% ethanol blend right now. I just switched over. after reading this, I realize I can richen the afr up some more. I was going for an 11.5 afr, but since I'm running 40% ethanol, can/should I go richer, and how much? also, the only thing I have changed in the tune is the maf table, because the E40 runs a lot leaner. one thing I noticed today when I was crunching the numbers to get the E40 is that since the gas pump has E70, if I mix equal parts of E70 with E10, it will make E40, so getting the right mixture is easy.
I also have 42.5lb injectors
I just switched over to E85 last week. Had it dyno tuned by ZZP. Good power but I still need to do some cold temp starting fine tuning.
what you mean 8 over? in the good fuel spark folder, the bottom rows are 10's. with dhp that 10 ends up being 15 in real life on a scanner. so what ever that value is figure its 5 higher really
like mine are set to 7's thats 13.5 for me.
and i dont recommend zeroing out that folder, so im not telling you where it is lol you can lean it out or add more fuel to it, but id not zero it.
I gotcha. Well based on my reading that tables not accessible in dhp anyway. So I guess I'll drop all my WOT timing by 8 in the good fuel table. It seems like a ghetto solution, but whatever
Sent from my SM-G935T using Tapatalk
its in the pe folder, time vs rpm. on corn you'd likely want to make it richer some.
on your scan whats your wot timing? or email me your bin so i can see what you set it to if your not sure what you did.
with hpt the value you see in the file is the actual timing, but not in dhp. its way different.
For the record, I couldnt find the AFR Spark table in PowrTuners anywhere, but I just opened Tiny Tuners for a different reason and it's right there in the Base Timing section under Spark. If anyones ever wondering![]()
What is a good tuner to get??
