A mini pipe wrench on the studs pad area (closest to the S/C) will remove it easily. There usually not in there that tight, at least the ones I messed with.
If its that tight, use to nuts on each stud, snug them together and use the nut closest to the case to pull out the stud (counter clockwise obviously)...
