I'd say its possible the motor died, could be really bad timing. I'd start to see if the motor is getting power then work backwards only because its easier. On 5 it should bypass the resistor if I remember right so if the resisitor was bunk or not it should still work on 5. Not sure if you mentioned checking fuses yet or not but thats also something to look at also.
