Thought I would post a little feedback.
I have had Diode Dynamic LED's installed on the entire exterior along with the LED tails. The flasher module worked to remove the hyper flashing but the turn signal arrows would appear on the HUD as well as the cruise control feature not working with the Diode Dynamic LED's in the 3rd brake light. The solution was adding load resistors to the 3157 front corners. This was working fine for the past year and all of the sudden the left turn signal appeared back on the HUD and would light up a couple of the LED's on the driver side Muth mirrors.
Took a closer look on the driver side corner thinking the load resistor lost it's connection. Connection was intact. Swapped a incandescent bulb and that fixed the issue. I recalled I had placed LED's into the turn signal indicators behind the cluster. I pulled the dash apart and replaced the turn signal LED's with incandescent bulbs and put the LED back into the driver side corner. This fixed the issue. I had the same issue on my 2002 Camaro with everything not functioning properly with LED's in the cluster gauge turn signals. Essentially not enough loading on the circuit.
Something to keep in mind for those wanting to run LED's everywhere.
