Thread: 97-03 Cluster Gauge LED Install
Results 1 to 20 of 77
  1. #1 Re: 97-03 Cluster Gauge LED Install
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by Loftus1995 View Post
    How did you go upon removing the red film? I have bought bulbs that are 194 (not sure how to install the LED's... Don't they need to go into a circuit???). The bulbs are blue, just need the red film to come off.
    Quote Originally Posted by Bronco Boy View Post
    He didn't remove the film, he just replaced the bulbs with LED's.
    Correct. I didn't remove the red film. I'm sure there is a way to remove the red film. You will have to figure that out. Have you tried rubbing alcohol?
    The plug in the same way as a regular bulb, except they are polarity sensitive (+ to +, - to -) or they won't work.
    This is correct. Complete plug in play.
    Quote Originally Posted by Logan541 View Post
    Hmm what if you use red bulbs with red film?
    You could use red LED's if you want. It will give you a true red color. The difference being that the odometer will also be red. I used to have a photo on my PC at home from someone that did it. I will post it up if I still have it.
    I'm looking forward to what Diode Dynamics brings to the table for the 194 size LED's. I am also considering changing out the behind the display of the digital DIC I have in my GT. I just need to find the exact size. I believe they are PC74 or PC37.
  1. Gauge cluster fix???
    By 92GPcoupe in forum General Tech Discussion
    Last Post: 02-28-2013, 06:02 PM
  2. Red Gauge Cluster
    By ShadowSwept in forum General Grand Prix Discussion
    Last Post: 09-09-2012, 04:04 PM
  3. le gauge cluster fuel gauge dnt work
    By cliffdawg in forum Visual/Body Modifications
    Last Post: 11-21-2011, 08:50 PM
  4. Swapping a 3 gauge cluster for a 6 gauge cluster
    By knoppsicle in forum General Tech Discussion
    Last Post: 10-16-2011, 09:49 PM
  5. Gauge Cluster
    By boy1dur in forum General Tech Discussion
    Last Post: 09-02-2009, 06:52 PM
