Quote Originally Posted by johntremell View Post
what did you use for a power source for the pump. I read the how to, but I don't remember seeing that. I was thinking I would use an "Add a Circuit" for my power source and use a fuse which turned on with ignition and off when the vehicle turns off. do you see any problem with that?
Yep, use an add a fuse n I ran mine to my fuel pump in the fuse box under the hood. Also make sure you use a relay
Sent from my SM-G900T using Xparent Blue Tapatalk 2
