Thread: Installing In-Channel Vent Visors
Results 1 to 8 of 8
  1. #1 Installing In-Channel Vent Visors
    gardner,mass
    Well sense i couldnt find anything on this and it was my first time doing so i figured ide do a short writeup to make things easier on other people.
    First thing i wasnt to sure if i wanted them, if i wanted stick on, or in channel. and i couldnt really find pics to get an idea so here are some.
    Without
    Stick on
    In-Channel
    So now for me the answer was pretty obvious.
    Well my first install didnt go so well because of the lack of directions that came with the vent visors (avs btw). I was thinking they were defective because they were not fitting properly and the window wouldn't go up so i defected that set out and obtained another.
    Now for the correct way to install these and save you guys a headache of trimming them or anything else.
    Make sure its somewhat warm or atleast heat up the 3m tape with hair dryer so that it can stick to its surface.
    First clean the inside of the channel with the handy alcohol wipes they provide you with.
    Next step is the most important part and i think why many people have problems with the fitment.
    See the edge where the rubber meets the paint on the edge of the window. The plastic tab that does not have 3m tape on it has to go in between these.This is what hold the visor forward so that the window doesn't get caught on the way up.
    Peel back the tape a little on each end before putting it in. This makes it easy to remove just in case the fitment is not correct.
    Put the window up to ensure that it does not get stuck on the way up. Then back down a bit if everything checks out.
    Now start from one side and remove the 3m tape plastic slowly.
    Put window back up and kind of tug behind the visor to ensure the tape is sticking to the inside channel.
    All done.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  2. #2 Re: Installing In-Channel Vent Visors
    GTP Level Member gpse2000's Avatar
    Apr 2011
    Fargo
    Nice Right Up!! I have the same ones, in channel is definitely the way to go! Key with installing is test fitting them and making sure the window goes all the way up like you touched on. The instructions were kind of poor so this def helps
    CLEANING TIP: I used the wipes provided as well as my own towel and alcohol to clean it better, mine was really dirty up in there
    2002 Denali Airaid MIT, Tint, 121k GARNET RED
    2006 GT S/C CAI, Plog, 3" DP, Flipped Mounts, DR STBs, SPO Grilles, SPO TIPS, Tint, Inlays, 120k BLEEN FOR SALE
    2000 SE 3.8 intake, dic swap, debadged, flipped mounts, rust mod 140k SILVERMIST SOLD
  3. #3 Re: Installing In-Channel Vent Visors
    if you have that fur like crap on the inside of the channel light sanding helps get it off, then the 3 m tape sticks better.
  4. #4 Re: Installing In-Channel Vent Visors
    gardner,mass
    Thanks Scotty, mine did and stuck ok without doing that but def a good idea for a better stick.
  5. #5 Re: Installing In-Channel Vent Visors
    Nice..I'd go in channel vs stick on as well.
  6. #6 Re: Installing In-Channel Vent Visors
    The Weathertech ones for the 97-03 don't use double sided tape. Idk about the 04+ ones though.
  7. #7 Re: Installing In-Channel Vent Visors
    GTP Level Member simbah's Avatar
    Lala land
    Quote Originally Posted by slick2500 View Post
    The ones I installed on my 06 did not have double sided tape(Weathertech)
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  8. #8 Re: Installing In-Channel Vent Visors
    SE Level Member Reazo's Avatar
    Jun 2013
    Southeast Nebraska
    Nice write up.. Have been wanting to get these for a while now but I keep putting it off. Got a link for some 04+ in-channel vents? Just wondering where you got yours
    2006 Grand Prix GT
  1. AVS In- Channel Vent Visors?
    By Timing in forum Visual/Body Modifications
    Last Post: 11-16-2013, 08:26 AM
  2. Visors?
    By Speedy1973 in forum Visual/Body Modifications
    Last Post: 04-30-2012, 05:25 PM
  3. vent visors
    By goldengtp in forum Visual/Body Modifications
    Last Post: 04-27-2011, 03:35 PM
  4. HELP installing vent leds, need to get dash off PLEASE
    By the2112 in forum Visual/Body Modifications
    Last Post: 12-15-2009, 09:21 AM
