Thread: de-smoking the tailights
Results 1 to 8 of 8
  1. #1 de-smoking the tailights
    Arizona
    Using just dupli color and a old sheet. I was able to remove 2 coats and a clear coat with out affecting the plastic. Hopefully somebody might find it useful. To restore your taillights back to normal afterwards just use some clear coat and you'll be back to normal.
    https://www.youtube.com/watch?v=LHJ_...e_gdata_player
  2. #2 Re: de-smoking the tailights
    Apr 2012
    Bancroft. Ontario, Canada
    Wish i knew about that stuff before i spent like an hour using a little gasoliene and a rag to de-smoke mine
  3. #3 Re: de-smoking the tailights
    Feb 2013
    Missouri
    I spent about an hour sanding mine off to re-tint them, wish I saw this before! Awesome find!
  4. #4 Re: de-smoking the tailights
    I use graffiti off from lowes, works good.
  5. #5 Re: de-smoking the tailights
    SE Level Member Thinksun's Avatar
    Sep 2012
    GTP Ontario
    1997 GTP .
  6. #6 Re: de-smoking the tailights
    Feb 2013
    Missouri
    Will this all work if you have clear coat over the VHT?
  7. #7 Re: de-smoking the tailights
    Apr 2012
    Quote Originally Posted by 91parkave View Post
    Quote Originally Posted by Booba5185 View Post
    I believe he said it does...
  8. #8 Re: de-smoking the tailights
    Goo gone in the can works good also
    04 Comp G.
  1. 02 GTP Tailights
    By GTPJIM in forum Visual/Body Modifications
    Last Post: 01-15-2013, 05:51 PM
  2. Brighter Tailights
    By gptrell502 in forum Visual/Body Modifications
    Last Post: 04-16-2010, 05:07 PM
