Thread: DIY - LED Turn Signal Mirrors, Puddle Lights, and Pontiac Logo Projectors!
Results 1 to 20 of 68
  1. #1 Re: DIY - LED Turn Signal Mirrors, Puddle Lights, and Pontiac Logo Projectors!
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    Quote Originally Posted by jrdaniels56 View Post
    I have the projector lights but I don't understand how they mount to the door panel do they come apart or does the o-ring hold them on? they look just like the gold ones you installed do you take it apart using the tiny holes in the end of the light?
    Thanks for the write up
    After you drill your hole in the door you should be able to twist the part closer to the lense and remove it. Then you will pull the wire up through the hole until your light is into the hole. Then you drop the other piece you took off down the wire and tighten so it holds it in the door panel. BE SURE TO SECURE THE LENS INSIDE SOMEHOW OTHERWISE IT WILL SPIN ON YOU AND WILL DRIVE YOU NUTS.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  2. #2 Re: DIY - LED Turn Signal Mirrors, Puddle Lights, and Pontiac Logo Projectors!
    Jul 2011
    ohio
    That's how I thought it worked but the lights I have won't come apart. Either I have a wrong style light or I'm gonna have to use pliers and see if it's just stuck together tight. Thanks
  1. Burgundy Bullet - Retrofit Pics and the End of the Bullet
    By burgundybullet in forum Members Rides
    Last Post: 02-18-2017, 02:26 PM
  2. How to: LED turn signal mirrors
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 09-01-2014, 08:17 PM
  3. Turn Signal Side Mirrors.
    By bkfelicetty in forum Visual/Body Modifications
    Last Post: 02-03-2011, 03:22 PM
