Thread: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
Results 1 to 20 of 177
  1. #1 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Arizona
    Quote Originally Posted by tms8582 View Post
    Great write up! I just installed a similar trans kit this weekend. I bought the intense kit which included a few more spacers, springs, piston seals, filter, gasket and assembly lube. It is twice the money however but from what people describe the end result in shifting is similar. INTENSE-Racing.com: INTENSEā„¢ Street/Strip Performance Shift PakĀ®
    The one thing that I would note is to be cautious with a trans flush on these cars.... especially with high mileage and no service records. I've spent a lot of time reading 3800 forums and have had several of these used w-body cars. In an older trans that has not been serviced the dirty coloration in the fluid is clutch particles and can be needed to get grip between the worn clutch rings. If you flush all of the old fluid out the trans it can start to slip soon after the service. Most experienced 3800 people suggest just dropping the pan, changing the filter and topping off with the fresh 8 quarts. On a trans that has really dirty fluid and starting the act up 7 quarts of trans fluid and a bottle of lucus trans fix usually will give some extra life to the trans.
    I don't know how many miles were on your trans but if the car has higher mileage I'd guess your trans has been serviced in he past. Your pan looks about as clean as I've seen so I'm guessing someone either took it really easy on the car and it has low miles or the trans has been serviced before. I've done a few pan drops on higher mileage of these cars and the pan and magnet is coated with grey crud. Just my 2 cents but great write up and pictures!
    Op mentioned a more or less trans fluid exchange not a flush a pressure flush is what screws **** up. But letting the fluid run out while putting new fluid in won't kill it, as its the same principal as dropping the pan.
  2. #2 Re: DIY How To Install TransGo Shift Kit 4T65E Very Detailed+Pictures
    Dec 2012
    Where 4T65E's were born
    Quote Originally Posted by 91parkave View Post
    Correct. I wouldn't exactly call it a full flush, or an exchange. It's kind of both because the fluid that was in the cooler/cooler lines was pushed out before the return line had a chance to dump the old fluid back in the pan.
    To put it in the best words, It's just a way to bring the normal 7/13 quarts of fluid changed up to about 9-10/13 quarts.
    Sold.
  1. Transgo Shift Kit-
    By GTByron in forum Introductions/Noob Questions
    Last Post: 04-01-2013, 01:18 PM
  2. Transgo Shift Kit Install Help
    By matthew911 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-15-2012, 06:22 PM
  3. transgo shift kit install Q
    By GTPJOE90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-10-2012, 11:19 AM
  4. 4t60e or 4t65e
    By gpboi19 in forum Introductions/Noob Questions
    Last Post: 02-02-2010, 05:21 PM
  5. Thrasher vs Transgo shift kit
    By anks106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-03-2008, 10:21 PM
