Thread: How to Remove the B-Pillar + Top of the Door Weather Strip '97-'02
Results 1 to 5 of 5
pgr1940 How to Remove the B-Pillar +... 06-02-2013, 03:21 PM
TLSheff Re: How to Remove the... 07-30-2013, 04:06 PM
coolone Re: How to Remove the... 07-30-2013, 04:12 PM
Neturu Re: How to Remove the... 09-29-2016, 10:25 AM
pgr1940 Re: How to Remove the... 09-30-2016, 10:17 AM
  1. #1 How to Remove the B-Pillar + Top of the Door Weather Strip '97-'02
    Donating Users
    Sep 2012
    LI, NY
    I found this write-up on the web. It has picture instructions on how to remove the B-pillar Trim/Appliques. I made changes to it to include the Top of the Door Weather Strip plus Part #s and links to the parts.
    Make sure you pay attention to how you take them out, to make sure that you put the weather stripping back where its suppose to be.
    You will need to remove the door panel in order to remove the mirror.
    How To Install Replace Remove a Door Panel on a 97-03 Pontiac Grand Prix 1AAuto.com - YouTube
    Tools needed:Slotted & Phillips Screwdrivers, 7MM socket.
    Take flathead and carefully pry out the plastic/rubber stopper at the top corner of the door:
    Take Phillips and remove the top screw:
    Take 7mm socket and remove the bottom bolt:
    Pry away the thick weather stripping. Pull towards you on the sides and downward at the top. Might take a little tugging and finesse to get it:
    Let the stripping hang by the mirror area and remove these 4 screws:
    Remove the upper portion by pulling outward and towards you.
    Again, might take some finessing:
    After strip is removed, it exposes 2 more bolts. One at the top, and there is one on the inside portion of the B-pillar:
    Now remove the B-pillar by wiggling and sliding upwards:
    Now just slide in your new or refinished B-pillar or Top of Door Weather Strip carefully
    and reverse what you just did and your done!
    B-Pillar: 97-02
    Driver side part#: 10315196
    APPLIQUE. Front Door Window Reveal
    Passenger side part#: 10315195
    Weather-strip Top Of Door:
    97-02
    Driver side part#: 10321353
    MOLDINGS/BODY-ABOVE BELT. Fits: Grand Prix | Nalley Buick GMC Brunswick
    Passenger side part#: 10321352
    With the part#s you can search around for cheaper prices.
  2. #2 Re: How to Remove the B-Pillar + Top of the Door Weather Strip '97-'02
    I live here. TLSheff's Avatar
    Nicely done. Had you use this for directions to a GP Facebook Group Member.
    Solid write-up and great pics, very helpful.
  3. #3 Re: How to Remove the B-Pillar + Top of the Door Weather Strip '97-'02
    Nov 2011
    NY
    Hahaha, how did you know I just got a huge chip in one of my B pillars?
    good write up, kudos!
  4. #4 Re: How to Remove the B-Pillar + Top of the Door Weather Strip '97-'02
    Sep 2016
    Chicago, IL
    I have DESPERATELY been looking for instructions on how to remove the chrome trim from my car... but the pictures are gone, is there any way to see these... ? A visual instruction would be great... any help would be appreciated.
  5. #5 Re: How to Remove the B-Pillar + Top of the Door Weather Strip '97-'02
    Donating Users
    Sep 2012
    LI, NY
    Sorry, I had them on my other computer which I don't have any more. I checked all my USB flash drives and couldn't find them. I don't have the GP any more.
    Phil
  1. How to remove the clips for the lower door molding retainer strip?
    By sschering in forum Visual/Body Modifications
    Last Post: 04-22-2013, 03:00 PM
  2. Metal Strip on Body Beneath Door Exterior?
    By Grand in forum Visual/Body Modifications
    Last Post: 09-14-2012, 10:05 PM
  3. Bottom strip on outside of door Coming off???
    By grandprix85 in forum Visual/Body Modifications
    Last Post: 04-22-2011, 09:27 AM
  4. Door Weather Stripping
    By stein2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2011, 06:06 AM
  5. Can you remove the B pillar trim on an 01?
    By atclarkson in forum Visual/Body Modifications
    Last Post: 05-16-2010, 09:33 PM
