Thread: Fixing your intermittent stalling problem!
Results 1 to 20 of 31
  1. #1 Fixing your intermittent stalling problem!
    Wooster, Ohio
    This is SOO easy and should be a sticky, cause it seems to be a common problem that people hunt for fixes by replacing uneeded parts. What happens is the Fuel Pump Resistor that selects between the pump cycling in low and high speed takes a dump, and here is the quick fix that just fixed my car 5 minutes ago for a problem i couldn't figure out hooked up to a Genesys. It would run about 5 to 10 seconds and just die without hesitation. It started stalling randomly on the road then continued to just get worse. Follow this image i found on another forum to fix your stalling issue.
  2. #2 Re: Fixing your intermittent stalling problem!
    GTX Level Member Confusingboat's Avatar
    Minnesota
    Could this also be a problem with 04+ cars? Because sometimes when I start mine it just stalls out.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  3. #3 Re: Fixing your intermittent stalling problem!
    SE Level Member popeyezTGP's Avatar
    Abbeville,Louisana
    do you know if this could be the same for the 1990 tgp mclaren ?
  4. #4 Re: Fixing your intermittent stalling problem!
    Wooster, Ohio
    uhm well since i don't own either car or ever worked on one for that matter, no...try it yourself but i do believe that the 2 speed pumps didn't come on anything till the series 2 3800, if you have a fuel pump speed relay then who knows, it might
  5. #5 Re: Fixing your intermittent stalling problem!
    boynton beach FL
    I have a 2001 gp gt and I have replaced that relay and it continues to stall.
  6. #6 Re: Fixing your intermittent stalling problem!
    Minnesota
    After looking back on this, I believe this only applies to the 97-03 GTPs (not the GTs) because they have a 2 speed fuel pump. What this does is force the fuel pump into high at all times.
    2015 Evo MR
  7. #7 Re: Fixing your intermittent stalling problem!
  8. #8 Re: Fixing your intermittent stalling problem!
    North Jersey
    mine does the same thing, drives me nuts, actually almost killed me and wrecked the car cause it stalled pulling out onto the highway... anyways, would i just put a little piece of metal between the resistor to help it function properly or just simply replace the resistor???
    and wouldn't this cut down on mpg's if it was permanently set to high??
  9. #9 Re: Fixing your intermittent stalling problem!
    Windsor (ON) Canada
    X2 on if this would lower gas milage??
  10. #10 Re: Fixing your intermittent stalling problem!
    GT Level Member jdmgtp's Avatar
    MI
    no it doesn't
    2000 GTP, 3.2 pulley, SD headers, 3" exhaust, modded 1.9's, custom CAI, LS6 maf, ported blower/ TB, HPT, 65 lb injectors, E85 in the summer, LM-1 wideband, 180 stat, autolite 104's, GMHD suspension kit. 13.2@104 on street tires w/o ported s/c
  11. #11 Re: Fixing your intermittent stalling problem!
    SE Level Member Blownl36's Avatar
    Jackson, NJ
    so would a 02 gt have a fuel pump resister? i see the gtps have it. pfyc has it for sale, so you can fix the stalling problem.
    Z7 Turbo kit w Intercooler/F1 Hood/F-Body Brakes/And some other go fast mods. Tuned and built by:
    http://tunetimeperformance.com/
  12. #12 Re: Fixing your intermittent stalling problem!
    Donating Users
    Sod, WV
    I am so glad I found this forum! Pittman06 kept me from going crazy. I have been trying to fix my '97 GTP for two weeks. I tried what he said, and it worked. Thanks so much.
  13. #13 Re: Fixing your intermittent stalling problem!
    North Jersey
    Quote Originally Posted by alfordtl View Post
    how did you fix it?!?!?!?!?!?!?!?!?!?!?!?!?!?
  14. #14 Re: Fixing your intermittent stalling problem!
    Donating Users
    Sod, WV
    I followed Pittman06's directions. Drove it all day yesterday with no problems.
  15. #15 Re: Fixing your intermittent stalling problem!
    North Jersey
    So I just basically bend out one of the prongs on the resistor???
  16. #16 Re: Fixing your intermittent stalling problem!
    Canada
    I've got a 1997 Grand Prix GTP Supercharge - On a 'cold start' she powers when starting ignition, revs go up as normal, levels down to idle speed but then 'pluffs' out (dies). She used to start after 3 goes but it's getting tougher to get her to fire without giving her gas to warm her up. What might be the prob? I hear that it can't be a choke as she has no carb...fuel injected...but wont there be a butterfly in there for air/fuel flow? Could it be the ECM sensor? Just want to have an idea, as a female, before taking her into a mechanic and maybe getting swindled...lol Thanks for any help! She runs fine on the road and has never 'stalled' out...ONLY when cold starting in the mornings. After sitting all day at work (9hrs) she is ok... Assistance GREATLY appreciated!
  17. #17 Re: Fixing your intermittent stalling problem!
    Minnesota
    Quote Originally Posted by GTP Gal View Post
    Clean your throttlebody.
    2015 Evo MR
  18. #18 Re: Fixing your intermittent stalling problem!
    Canada
    ...will give 'er a go....cheers
  19. #19 Re: Fixing your intermittent stalling problem!
    Donating Users
    Sod, WV
    Fuel filter may be the problem, also. It is an easy fix.
  20. #20 Re: Fixing your intermittent stalling problem!
    Jan 2009
    Long Island
    i went wit my fuel pump and that fixed it.Pressure was lacking alittle.
  1. Stalling problem
    By 97gp97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2011, 09:28 AM
  2. Intermittent Engine Stalling Problems
    By BADAZGTP in forum How To Write-Ups/Tech Tips
    Last Post: 08-23-2010, 10:46 AM
  3. Intermittent dying problem with 00 GTP
    By ls6velless454 in forum General Tech Discussion
    Last Post: 04-08-2010, 12:11 PM
  4. Intermittent Starting Stalling Issue
    By daniel981 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2009, 07:20 AM
  5. Intermittent Engine Stalling Problems
    By BADAZGTP in forum General Tech Discussion
    Last Post: 05-16-2008, 07:59 AM
