Thread: Quick LS4 Belt Removal
Results 1 to 9 of 9
  1. #1 Quick LS4 Belt Removal
    Arizona
    Props to whoever posted it on GMLS4.com i cant remeber the picture but there damn sure isnt a writeup anyway it goes as follows
    No need to remove the wheel at all just crank the steering wheel to the right
    use a 4' hose clamp bend it like so
    Use a 8 mm socket and ratchet and start tightening it down eventually it will conform around the tensioner and voila! you you can take off belt by hand no expensive tools no headaches quick and easy
  2. #2 Re: Quick and Dirty LS4 Belt removal
    I live here. DirtDog's Avatar
    Jun 2012
    i did it once like that after you told me how to. and btw you should update your sig now
  3. #3 Re: Quick and Dirty LS4 Belt removal
    Jun 2012
    i really think this should be stickied in the 5.3 section. i send a link to this to people all the time
  4. #4 Re: Quick and Dirty LS4 Belt removal
    So this avoids the issue of the tensioner popping out and dropping quite a bit...I like.
    Glad you posted this before I swapped the PS pump this weekend Stickied.
  5. #5 Re: Quick and Dirty LS4 Belt removal
    I put it in the how to section and left a permanent redirect from where the original thread was. How's that?
  6. #6 Re: Quick and Dirty LS4 Belt removal
    Jun 2012
    Works perfectly! thanks. I honestly send a link to this to people on a weekly basis
  7. #7 Re: Quick and Dirty LS4 Belt removal
    Arizona
    hanks for putting this up guys. I should edit this to show the prybar method which is even quicker
  8. #8 Re: Quick and Dirty LS4 Belt removal
    Jun 2012
    add it in the first post as an option 2 method
  9. #9 Re: Quick LS4 Belt Removal
    Wichita
    Eeesh..cant believe I only now am stumbling upon this post. Super dooper useful this.
  1. Quick LS4 Belt Removal
    By 91parkave in forum 5.3L V8 (LS4)
    Last Post: 08-12-2014, 08:15 AM
  2. My easy, not professional belt removal
    By fisher580 in forum 5.3L V8 (LS4)
    Last Post: 01-12-2014, 11:42 PM
  3. Size wrench needed to adjust belt tensioner for accessory belt install?
    By fju2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-03-2011, 09:29 PM
  4. Quick Question about Supercharger Belt
    By TheAce144 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-16-2011, 07:01 PM
  5. Alternator Belt Removal Help
    By Talsition in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2008, 02:59 PM
