Thread: Engine Coolant Temp Fluctuating
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 Engine Coolant Temp Fluctuating
    GTX Level Member webracin's Avatar
    Arkansas
    I figured out some valuable information and thought I would share it with you all.
    Issue: Cooling temp constantly changing from around 210* to 180* and back to 210*. When at 210* there is no heat inside the car, but when it drops to 180* there is heat inside the car.
    Solution: If you have worked on ANYTHING that requires messing with ANY part of the cooling system, you must bleed the air out of the cooling system using the bleed screw on top of the thermostat housing. Failure to do so will result in an air pocket forming in the top of the engine which can cause the thermostat not to open resulting in the car overheating. You can also have steam pressure in the top of the engine build up enough that coolant will not flow through the heater core inside the car causing you not to have heat in the cabin.
    The car should be cool when adding fluid. Take off the radiator cap and top off the radiator, then start the car. Open the bleeder screw about 1 full turn. As soon as you see coolant dribble out, close the screw and top off the radiator again. Open the bleeder screw again about 1 full turn, close it when you get a steady stream of coolant coming out of the bleeder screw. Top off the radiator one more time and replace the cap.
    Hope this helps you guys
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  2. #2 Re: Engine Coolant Temp Fluctuating
    PA
    I noticed this same exact thing happen in my car. But I noticed it when I had a water pump slowly leaking. As the coolant would get low, the temp would start to fluctuate more. So I knew it was time to add coolant.
    2001 GSE
  3. #3 Re: Engine Coolant Temp Fluctuating
    Barksdale AFB, LA
    Any time I crack open the cooling system, I always bleed it. Good insurance and keeps the system air free.
    2009 Subaru Impreza WRX STI
  4. #4 Re: Engine Coolant Temp Fluctuating
    Arkansas
    Very true and I do as well, but when those damn plastic elbows crack on you and you lose some coolant its a little strange to see the temp guage go up....no heat....go down......HEAT....drove me nuts till I got home and found the leak.
    webracin
    2001 Grand Prix GTP
  5. #5 Re: Engine Coolant Temp Fluctuating
    Spokane Washington
    i had the same thing happen to me low coolent light would come on but yet no puddles in the driveway till one day i noticed the temp going up and down and the heater blowing cold air like you said. One day coming out of the store i found a puddle under the car put it up on the lift and it looked like the wheep hole in the water pump leaking, we and got a new delco WP and stated tearing it down to find that damn elbo broke. Made me feel kinda good to finaly find out what the problem what for a while i had nightmears of coolent getting into the crankcase!
  6. #6 Re: Engine Coolant Temp Fluctuating
    Feb 2008
    Good info Web!!
  7. #7 Re: Engine Coolant Temp Fluctuating
    SE Level Member CSteen85's Avatar
    Long Island, NY
    Quote Originally Posted by webracin View Post
    webracin
    This is what is happening to me right now. If I am understanding this thread correctly, would replacing my upper and lower radiator hoses fix this problem?
    My mechanic said I needed to have them replaced and I'm just wondering if this could be causing my heat inside the car to be going in and out and my temp gauge to be rising and falling a bit.
    Is this right?
    1997 Grand Prix SE, 3.8L V6 SFI, 140k, purchased on 3/6/10.
  8. #8 Re: Engine Coolant Temp Fluctuating
    what he is talking about replacing are two plastic elbows,not the rubber hoses. If your upper and lower radiator hoses are not leaking,dry rotted ,or cut ...leave them be.
    Snorlax strikes again.
  9. #9 Re: Engine Coolant Temp Fluctuating
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    Quote Originally Posted by CSteen85 View Post
    Is this right?
    no, you probably have an air bubble in the system. webracin explained how to fix that. Take a pic of the hoses and post them, we'll tell you if they're good.
  10. #10 Re: Engine Coolant Temp Fluctuating
    GT Level Member GreyGhost's Avatar
    Nov 2009
    IL
    Another way is to just run with the cap not tightened all the way closed. Just unscrew it that first 1/4 turn and it will vent the air out that way. Been done that way for years before any air valves were put in the system.
  11. #11 Re: Engine Coolant Temp Fluctuating
    the bleeder is still higher in the system.
  12. #12 Re: Engine Coolant Temp Fluctuating
    Nov 2009
    IL
    It is, but you have no guarantee that you have all the air out. With the cap cracked it will pressurize and push the air out without losing fluid. Just let it warm up until the thermo opens and let it cycle for a few minutes and it will push the air out and leave the fluid in.
  13. #13 Re: Engine Coolant Temp Fluctuating
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    wait so you have to bleed that thing averytime you add or check coolant level?
  14. #14 Re: Engine Coolant Temp Fluctuating
  15. #15 Re: Engine Coolant Temp Fluctuating
    grand haven mi
    thank you for this info this is goig to save me some $$ i am going threw this right now the plastic elbow now is that down bye the (gooseneck) or down by the water pump
  16. #16 Re: Engine Coolant Temp Fluctuating
    Fort Collins
    Where is the bleeder screw on a 2001 GTP?
  17. #17 Re: Engine Coolant Temp Fluctuating
    Jul 2008
    sumter,south carolina
    on the thermostat housing... which is attached to teh right side of the lower intake mani.
    02 GTP with mods 05 GP for DD
  18. #18 Re: Engine Coolant Temp Fluctuating
    SE Level Member Lacboi's Avatar
    Jun 2010
    Atlanta
    drilled t stats ftmfw lol
  19. #19 Re: Engine Coolant Temp Fluctuating
    GT Level Member UCF04GPGTPCompG's Avatar
    Nov 2009
    Clermont, Florida, USA
    when bleeding the air out with the screw, are you supposed to leave the radiator cap off so the system doesn't gain pressure, or are you supposed to leave it on to help push that air out?
    2004 Pontiac Grand Prix GTP Competition Group (250K)
    Engine Mods: K&N Air Intake, ZZP 3'' Downpipe w/MagnaFlow Cat
  20. #20 Re: Engine Coolant Temp Fluctuating
    leave cap off, start car till its at operating temps, when the fan turns on you know the t state is open, unless you see the radiator level drop, if it does then re top it off, open the screw, let the air bubble out, till a stream of coolant comes out, shut screw, top off rad, cap it, done.
  1. ambient air temp sensor
    By Toasty in forum General Tech Discussion
    Last Post: 09-10-2011, 10:12 PM
  2. temp on aeroforce and temp on dash
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 01:05 PM
  3. Temp fluctuation
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 10-11-2008, 08:28 PM
  4. Engine Coolant Question
    By dowtrader in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2008, 03:03 PM
  5. Motor Temp Creeping Up
    By Gearhed42 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-11-2008, 06:05 PM
