Thread: Retrofit on a 2001 Gtp with (many pics)
Results 1 to 5 of 5
  1. #1 Retrofit on a 2001 Gtp with (many pics)
    Apr 2013
    Michigan
    Well guy's thought i would make a nice write up for you guy's on how to retrofit your Gtp. I know ls1 did this as well but i thought heck make another might as well. I'll start off by saying equipment im using
    Ballasts: 35w morimoto
    Bulbs: H1 5000k
    Harness: Morimoto control relay
    Halo ring: Xb-Led ring's newest version
    Shroud's: Mini-gattling gun
    Projectors: Mini-h1 6.os
    Step one: Go to your local junk yard try and find Stock housing's. Reason why i say stock is because the one's off ebay are cheap the lenses crack very easily(you can tell there off ebay by the housing's being usually grey) im just using one in this pic to show i did end up using stock black housings.
    Uploaded with ImageShack.us
    Next your going to want to pre-heat your oven that you are using in either your or your mom's kitchen haha. The temp. your going to pre-heat it to for these headlights since there not perma-seal and don't have to deal with that is going to be the degree on the picture below.
    After you slowly used a small screwdriver and a bigger screwdriver as well and slowly pryed at the housing and the lense you should of ended up with this.
    now onto some cutting. as you can see the stock halogen bulb holder is still here.
    We don't need that and we won's be using it and this is why as you can see the thread's are not going to go past the holder.
    So use your dremel and cut-off that holder you will no longer need it and now you should have something like this.
    But that is deff not pretty at all by no mean's now if your just doing this to get overwith don't care how look's in back go forth. But me i did wanted it to be alot cleaner then that. So get yourself an angle sander if you don't have one get one at harbor frieght they work great. But after sanding here's what i got.
    Now if your using the mh1 6.0s you must take a step further with your sanding and you have to make it so the holder has like a lip in it deeper. here is what i mean by that on the picture below
    just added some kwik weld to around back before lock nut because there was a little space between so wanted to be sure to ensure a great seal and i fig was awake why not haha
    now here is a shot with shroud's on i used screws on holes of shround plug a little bit of gorilla glue just for extra safety.
    shot of both assemblies done with shroud's on laying on floor just some test shots
    On the vechile now but no lenses ready for alignment hope you guy's liked my write up an questions at all please feel free
    Uploaded with ImageShack.us to ask.
    and last but not least a picture of the cutoff but still need to do some fine tuning as you can see but looking good
  2. #2 Re: Retrofit on a 2001 Gtp with (many pics)
    Apr 2013
    Michigan
    Well guy's i thought i might update this as i finally finished my retrofit completeley. I ended up taking my turn signal housing's apart as well and painting them flat black to match the headlight's came out great i think. was gonna do led arrow's but when i photoshopped it i deff didn't like the look. Also clamped the housing's no leaking yet 250 degree's for 5 mins. then let cool for half hr.
    VHT high temp paint(painted the housing's with 4 coat's each assembly)
    [IMG=http://imageshack.us/a/img850/296/dipit.jpg][/IMG]
    Next i went and got all the old sealant out with a screwdriver and also used little bit or gorilla super glue for the orange arrow because normally it just sit's in there.
    [IMG=http://imageshack.us/a/img829/8499/beforeafterpic.jpg][/IMG]
    While i was just finishing up the turn signal's i thought since i had them done sealed after waiting to harden up. I went and sealed/clamped the headlight housing's.
    [IMG=http://imageshack.us/a/img18/1858/clampedone.jpg][/IMG]
    Final shot of everything done. The second picture reason why light came out blue something off my flash reflected from my cell phone i think. There pure white 5k.
    [IMG=http://imageshack.us/a/img248/3388/sgreat.jpg][/IMG]
    Uploaded with ImageShack.us Hope you guy's enjoy the write up/pics.
  3. #3 Re: Retrofit on a 2001 Gtp with (many pics)
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    Cool.
    The stock headlights on ebay aren't junk, they are as good as OEM in my experience, and are also MUCH easier to pull the lenses off since the glue is still fresh.
  4. #4 Re: Retrofit on a 2001 Gtp with (many pics)
    Apr 2013
    Michigan
    here's another update guy's wanted to do something diffrent haven't really seen on a Gtp. I wanted to make her angry i used Alpena flat black vinyl can buy it at your local autopart's store. worst part was getting em dead on close to each other. lmk what you think.
    Shot of her without my 5k's lit up man she look's mean.
    With the 5k's lit up i was gonna go all across i tried it but didn't look as good.
  5. #5 Re: Retrofit on a 2001 Gtp with (many pics)
    Apr 2013
    Michigan
    i never had good luck with ebay headlight's ls1 just my personal experience with em. i noticed the plastic is alot more cheap not as durable as oem.
  1. Post Retrofit Pics
    By DanPrixGTP in forum Visual/Body Modifications
    Last Post: 02-19-2012, 11:06 AM
  2. Retrofit help
    By DukesGTP in forum Visual/Body Modifications
    Last Post: 12-04-2011, 06:04 PM
  3. 2004 Projector Retrofit and Lowering Springs!! +pics!
    By colindunn in forum Visual/Body Modifications
    Last Post: 08-17-2011, 11:08 PM
  4. Retrofit help
    By GPGT2004 in forum Visual/Body Modifications
    Last Post: 07-07-2011, 03:12 PM
  5. my 2001 grand prix gt/pics matte black roof
    By tesh123 in forum Members Rides
    Last Post: 05-30-2011, 04:48 PM
