Alright I keep referring to this on Tapatalk and that means searching for it every time. I'll give an update on where I'm at, and also get this post on my subscribed list.
I got the headlights apart, had to go to 250 for an additional 10 minutes for one of the new headlights, and actually another 10 on top of that at 270 for the other. They were sealed really well for some reason. The turn signal housings were from a different manufacturer and came apart like butter.
I've got the glue out of the channels using a heat gun and a screwdriver, and the back mounting area sanded down flat. I had to shave the projector down quite a bit, not talking about the shroud. That will be a bunch of trimming. I'm just unsure of how far off the beams will be on the rough hook up, when sanding there's no judging what the angle of the sanding will show on the projectors so I just did what this thread said. More towards the outside(actually sanding more in the inside so that the projector actually faces outwards more) tonight will be sanding and painting.
Good write up.
