Thread: Car Running Bad HELP
Results 1 to 5 of 5
  1. #1 Car Running Bad HELP
    Feb 2013
    Canada
    I recently changed the valve cover gaskets, intake gasket, supercharger gasket and thermostat on my 99 gtp
    It's all back together but runs like crap now, the idle isnt as good as normal and the engine shakes a little more than normal too, kind like a little knock.
    any ideas and tips of what it could be or what i should check?
  2. #2 Re: Car Running Bad HELP
    I wanna guess you missed a vacuum line somewhere or a plug wire is in the wrong spot.
  3. #3 Re: Car Running Bad HELP
    if you didn't change the vac line ends or T's or one cracked, or ones cracked where you cant see it, it will run poorly.
    get a can of carb cleaner and spray around the vac lines, if the idle jumps up, you have a leak in that area.
  4. #4 Re: Car Running Bad HELP
    Feb 2013
    Canada
    theres an air leak coming from the bottom of the SC bypass,
    Google Image Result for http://ww2.justanswer.com/uploads/superbovine/2010-04-04_183929_Untitled.jpg
    underneath where the little rod goes in,
  5. #5 Re: Car Running Bad HELP
    Feb 2013
    Canada
    Just found
  1. Anyone running these?
    By h0wl0ngcanitbe in forum Visual/Body Modifications
    Last Post: 04-16-2012, 03:43 PM
  2. Car is running hot !!!
    By Dobbs122 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-13-2011, 08:41 AM
  3. Who's running low 14's?
    By Louie3 in forum Off Topic Discussion
    Last Post: 08-02-2010, 09:24 AM
  4. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  5. Anyone running 245/50 R16's ?
    By rynoman03 in forum Tires & Wheels
    Last Post: 08-14-2009, 02:53 AM
