Thread: How to clearance your stock cast bracket for an intercooler and belt BillBoost way
Results 1 to 12 of 12
Threaded View
  1. #1 How to clearance your stock cast bracket for an intercooler and belt BillBoost way
    The other day I had this thought.. Today talking to a fellow GP'er I bolted a spare bracket to the motor and went to work. 30 minutes total invested to this point.
    The whole premise was.. the belt only catches a little under a 1/2 inch of the bracket. Why not remove some of the excess and slide the bracket over, seemed possible..I went to work.
    Using a 4 1/2 cutoff wheel, then a carbide grinding bit to finish it off a little. Here's the pics.
    Remove your coils, icm and pack mounting plate. May need to put the bracket in a vise. My motor was out already. Then cut in across the bottom to make the area flush with the old area that the pack mounted to and then cut down from directly above to complete the corner.
    Bad angle, but I could see this cleared
    Redrill at least two of the three holes and mount.
    Like I said..this was a quick and dirty prototype to see if it was possbile. Dammit..it's going to work like a charm.
    SuperEasy Easy
  1. 04+ Intercooler install?Alternator bracket
    By Explicit_Spade in forum 04+ Specifics
    Last Post: 01-27-2012, 04:35 PM
  2. Gatorback Belt size for stock S/C?
    By SnowDrift in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-01-2011, 03:44 PM
  3. Intercooler on a stock gtp ?
    By boostedgtp13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2010, 11:57 PM
  4. Should I use a stock belt with a 3.5 pully?
    By ncccgolf5 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2009, 08:24 PM
