Thread: Vent Guage Pod for 97-03
Results 1 to 15 of 15
bsharpminor Vent Guage Pod for 97-03 01-09-2013, 06:50 PM
coolone Re: Vent Guage Pod for 97-03 01-09-2013, 07:15 PM
Swiggles Nice job! 01-09-2013, 07:43 PM
Iceman6669 Re: Vent Guage Pod for 97-03 01-09-2013, 09:06 PM
Fivefingerdeathpunch Re: Vent Guage Pod for 97-03 01-09-2013, 09:41 PM
Timing Re: Vent Guage Pod for 97-03 01-13-2013, 09:04 PM
LS2 BLAZER Re: Vent Guage Pod for 97-03 01-09-2013, 09:55 PM
Dee23 Re: Vent Guage Pod for 97-03 01-12-2013, 01:02 AM
TexasTanker19kilo20 Re: Vent Guage Pod for 97-03 01-12-2013, 01:17 AM
pontiac4lifesc Re: Vent Guage Pod for 97-03 01-13-2013, 09:28 PM
bsharpminor Re: Vent Guage Pod for 97-03 01-14-2013, 09:28 PM
Elrodd384 Re: Vent Guage Pod for 97-03 01-14-2013, 10:18 PM
pontiac4lifesc Re: Vent Guage Pod for 97-03 01-15-2013, 10:43 PM
asite57 Re: Vent Guage Pod for 97-03 01-18-2013, 12:32 PM
bsharpminor Re: Vent Guage Pod for 97-03 01-19-2013, 04:13 PM
  1. #1 Vent Guage Pod for 97-03
    GT Level Member bsharpminor's Avatar
    Mar 2012
    Minnesota
    So I bought Aeroforce Scangauge for my '03 GTP to scan for KR and I only got one so I didn't want an HUD or pillar pod so I made one work in the left center vent.
    I bought a second dash shroud from a scrap yard in case I messed up bad, I didn't want to be lost without one.
    You will need a drill, a hack saw, a file, an extra piece of plastic, some plastic epoxy and paint if you want it (be sure to use paint designed for plastic).
    I couldn't manage to find any solid plastic around the house so I ended going to Target and found a wall file box and hacked it up.
    I pulled of the dash piece off and drilled off the plastic welding that holds the vents on.
    Pulled the vent apart and cut the plastic close to size, then filed and test fitted it a thousand times.
    When it fit, I then painted the plastic piece and put it in the vent with epoxy.
    I let it dry, then put the shroud back on the dash and used epoxy where the plastic welds were.
    Let it dry, then put your gauge in and put your car back together.
    A pic without the flash:
    The gauge ends up being a little recessed, I am not sure whether or not I like it, but it will do the job for now. I also didn't put anything in the vent to stop air flow, but I am likely going to go back and add some insulation.
  2. #2 Re: Vent Guage Pod for 97-03
    Nov 2011
    NY
    Nice job... Not sure if I like it but nice none the less.
    Quincy, Mass
    Nice job!
    No more GP 04 Impala SS Indy:
  4. #4 Re: Vent Guage Pod for 97-03
    The Boss Iceman6669's Avatar
    Jun 2011
    Looks legit... Like to find NEW places to stick gauges... More RACEKAR..
    2011 F-150 Yote powered
  5. #5 Re: Vent Guage Pod for 97-03
    I wouldnt even worry about the air flow, it wont hurt the gauge whatsoever.
    Nice work though.
  6. #6 Re: Vent Guage Pod for 97-03
    gardner,mass
    Nice work though.
    i was wondering about that, so if i blast my heat into the aeroforce it isnt going to hurt it?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  7. #7 Re: Vent Guage Pod for 97-03
    Donating Users LS2 BLAZER's Avatar
    Lorain, OH
    thinking outside the box... i dig it...
    2001 Grand Prix GT - stock (for now )
    2007 Trailblazer SS - back under the knife , motor #4 on the way
  8. #8 Re: Vent Guage Pod for 97-03
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    Nice, very creative....similiar to the Mustang Roush vent gauge. I have a 00' Regal GS so my cluster/vent panel is a lil diff from the GTPs. Is there a lil easier way to this for a Regal or is this the best process?
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  9. #9 Re: Vent Guage Pod for 97-03
    Sep 2011
    Copperas Cove, TEXAS
    Nice write up with pics and looks good.
  10. #10 Re: Vent Guage Pod for 97-03
    SE Level Member pontiac4lifesc's Avatar
    Mar 2012
    Winona, MN
    i did this to mine last year i like it a lot and had no problem with mine, now have aeroforce inplace
  11. #11 Re: Vent Guage Pod for 97-03
    Mar 2012
    Minnesota
    Quote Originally Posted by pontiac4lifesc View Post
    Yours looks like it sits farther forward than mine. Do you think you did anything different than me based on the info above?
  12. #12 Re: Vent Guage Pod for 97-03
    SE Level Member Elrodd384's Avatar
    Mar 2012
    Fort Campbell, KY
    bravo man, that looks great!
  13. #13 Re: Vent Guage Pod for 97-03
    Mar 2012
    Winona, MN
    i didnt even know there was a thread bout this, i seen this done in couple 2g talons and thought it was different. i just pulled mine apart gutted the vent area and use sheet metal right up against the back and used epoxy to hold the sheet metal in.
  14. #14 Re: Vent Guage Pod for 97-03
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    You honestly could make and sell a few of thos plastic pieces man just something to think about you have a templet
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  15. #15 Re: Vent Guage Pod for 97-03
    Mar 2012
    Minnesota
    Quote Originally Posted by asite57 View Post
    There would have to be a fair amount of interest for me to do this as I'd have to pull the one I am using apart for an accurate template.
  1. Need to vent
    By zildjian102 in forum The Rant Forum
    Last Post: 08-13-2010, 11:20 AM
  2. down the vent
    By echarleswhyte in forum General Tech Discussion
    Last Post: 09-21-2009, 06:46 PM
  3. Air vent issues
    By Draygyen in forum General Tech Discussion
    Last Post: 01-28-2009, 11:58 AM
  4. vent mount
    By gotboost3 in forum Visual/Body Modifications
    Last Post: 12-05-2008, 05:59 PM
  5. i have the need to vent
    By stlmo_gtp in forum The Rant Forum
    Last Post: 04-09-2008, 10:03 AM
