Thread: Power Steering Pump Replacement [*]
Results 1 to 20 of 29
  1. #1 Power Steering Pump Replacement [*]
    I live here. UR LOSN's Avatar
    Rockford, IL
    This HOW TO write-up on Power Steering Pump Replacement has been added to the How To section and can be found HERE
    I will have pics of this soon as I had to change mine out 2 days ago.....nothing like -5* ouside!!!
    GT Level Member bad1999gtp's Avatar
    eau claire, wisconsin
    nice i think i will be doing this soon cause i think the ps is making thesqueal noise i hear
    ported m90,ported lower,160 tstat,headers,3in dp,cat&resi delete,flowmaster 44's,103's,zzp ic,42.5 inj,N*,3.4 pulley,cust. pcm,ported heads,cai,drilled&slotted rotors,gmpp sway bars
    and question how d you guys get all your info in your sig i can not get all mine to go in keeps tling me to many lines
    Rockford, IL
    we're special. jk. it will allow up to 6 lines. I just copid and pasted my entire list of mods..and started to delete it..until it finally took it. and this is what I have left.
    is the pump whining? or a belt sqeel?
    well its not a belt and i am not sure if its the pump yet. have not had a chance to get it in the garage. But it does it at idle and then when i get on it it gets louder. And yes it is full of fluid. I am just hoping that it is that and nothing else
    Banned
    Texas
    mine does the same bad1999gtp
    yeah i dont know but i im'd him and he told me to do something about pasting them in
    Banned
    Texas
    well i would like to know what to do and know why it is making that noise.
    GT Level Member DuBob's Avatar
    Lititz, PA
    Quote Originally Posted by UR LOSN View Post
    the PS steering pump is held on by 2 12mm bolts(if memory serves me correctly). you have to go through the PS pulley with a socket in order to get to them.
    12. put everything else back on(including PS cap)....start vehicle...turn wheel left and right 5 more times, turn off vehicle. recheck fluid level. recheck PS lines for leaks. if no leaks are found, great job, now put the old pump back in the box, and return it for a core charge. and grab a bear and sit down. like to add, if you have small hands....this job should not be a problem...
    The bolts are 13mm and what part of the bear do we grab?
    And for any torque/ft-lb nazi's out there, the bolts are 25 ft lbs.
    One of the First: 2008 Liquid Red Pontiac G8 GT (hers)
    -Intake, Tune, Magnaflow Exhaust, 40% tint.
    -Next: Rims, lowered?, headers?
    One of the Last: 2009.5 Stryker Blue Metallic Pontiac G8 GXP M6 (mine)
    -Intake, Magnaflow Exhaust, 25% tint.
    -Next: Headers and tune.
    Banned
    Texas
    what is causing the squealing noise?
  11. #11 Re: Power Steering Pump Replacement [*]
    Feb 2009
    Dayton ohio
    i have a 97 gtp and can't figure out were to add power steering fluid please help me thanks dustin
  12. #12 Re: Power Steering Pump Replacement [*]
    Rockford, IL
    toward the back of the engine bay, UNDER the Alternator.... you will see the cap.
  13. #13 Re: Power Steering Pump Replacement [*]
    Feb 2009
    Dayton ohio
    thanks for the help.
  14. #14 Re: Power Steering Pump Replacement [*]
    SE Level Member gggromit's Avatar
    Canada
    Bump for pictures
  15. #15 Re: Power Steering Pump Replacement [*]
    Dec 2008
    Indianapolis, IN
    I'm sorry if bumping threads is against the rules (I didn't see a ruleset anywhere) -- but I'm likely going to tackle this over the weekend on my 03 GT. Is rocking the motor forward necessary?
    A bit of info -- I took it to the shop because of a belt squeak. They were "positive" it was the belt tensioner, so I replaced it. It wasn't. Looking down while the engine is running the only pulley that rocks back and forth is the PS pulley, leading me to think the bearings are shot. It's a intermittent squeak, not a constant one. My thought is to remove the belt then check for play in that and the A/C unit (the alternator is fine). Thoughts? I've never done a PS pump before, and I don't want to replace the wrong part yet again. That was a 100.00 mistake that I should have thought of sooner.
  16. #16 Re: Power Steering Pump Replacement [*]
    Minnesota
    when i start my car up in the morning it squeals im pretty sure its a belt i think the ps belt. it goes away once the car is warmed up. sometimes my power steering goes out and comes back when i give it a little gas and then you can hear the pump squeal when i turn. does that mean i need a new pump and belt?
  17. #17 Re: Power Steering Pump Replacement [*]
    Apr 2009
    Baton Rouge, Louisiana
    My 07 GT did that. Dealer installed a new Pump been quiet since. New pump is the only fix don't kid yourself. Belts not a factor unless its really worn.
  18. #18 Re: Power Steering Pump Replacement [*]
    USA
    Is the write up for all years?
    Stattama T67 Turbo, A2A IC, SLP Cat Back Exhaust, Oversized ZZP radiator, ZZP 1" Transmisson chain, PRJ Ignition Wires, MSD Ignition Coils, Inferno Ram Air Hood, Powerslot Brake Rotors and Pads, 18" American Racing Muscel Phanton, HP Tuner
  19. #19 Re: Power Steering Pump Replacement [*]
    Indiana
    Most Grand Prix r the same from 97-05 or 06 really with the ps... And if its whining it your ps pump man.. heres what u do go to a junk yard and see if u can find a 3800 engine pulled out and get the pump. in indiana it like 22 bucks, jus make sure it looks decent. but if u gotta order one, it only 2 13mm bolt that hold it on, they are directly verticle from each other. get a socket and extension and go through the holes in the pump to get to the bolts.
    side note: take the belt off, and the coolant bottle (99+) and to get it out, you'll have to take the first hose goin to the engine (farest to the left) supply's coolant to your engine. some will spill out, its ok, jus make sure your engine is cool, otherwise you'll burn the crap outta ur hands. have any questions post em on there. jus did mine, turn a 257.99 problem, into a 22.99 problem doin it myself
  20. #20 Re: Power Steering Pump Replacement [*]
    Grand Rapids, MI
    or just throw the coolant tank to the side without disconnecting any hoses lol. i'm lazy
    i got a used pump from morad for $30 bucks. cheapest solution. works like a charm.
  1. Repair Your Power Windows Switch[*]
    By J_Ferguson in forum How To Write-Ups/Tech Tips
    Last Post: 10-19-2013, 01:07 AM
  2. Without power again
    By Rocket468 in forum Off Topic Discussion
    Last Post: 04-21-2011, 12:50 AM
  3. Change Oil Soon Light
    By thermanlee in forum General Tech Discussion
    Last Post: 04-29-2009, 08:47 AM
  4. 2005 Power Steering Pump Seems Thrashed
    By Myoldmopar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-12-2009, 07:28 PM
