Thread: Power Steering Pump Replacement [*]
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: Power Steering Pump Replacement [*]
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    dont forget the oring lol
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  2. #22 Re: Power Steering Pump Replacement [*]
    Utah
    Sorry to bump an old thread. I need to replace my pump, the link to the write-up isn't working anymore. Any have write-up they can post for me?
  3. #23 Re: Power Steering Pump Replacement [*]
    take the belt off, take the 2 lines off the bottom, one threads in the other has a hose and clamp. the p/s pump pulley has a hole in it, you stick a socket thought the hole to get to the 2 bolts, one is at the 12 o'clock and the other is at 6.
    remove the alt for some more room and viability.
    remove the dog bones pull the engine forward and it should come up and out, if not it can also be pulled out through the wheel well.
    your new pump should come with a pulley puller to remover your pulley, then you need to put it back on the new pump. ( same puller puts it back on) dont try to remove the pulley till after the pump is off, theres just not enough room to get it done.
  4. #24 Re: Power Steering Pump Replacement [*]
    Apr 2013
    Colorado Springs, CO
    Yeah I did it the hard way, I removed the pulley while the pump was still in the car. How? Pry bar. Gentle pressure, twist pulley, repeat. After I got that off I noticed the holes in the pulley to remove the bolts. Fuuuuu............ I'm an idiot.
    Question, anyone have a diagram of where the power steering lines run? I'm replacing pump and lines since the car is 13 years old and is leaking p.s. fluid everywhere.
  5. #25 Re: Power Steering Pump Replacement [*]
    SE Level Member jjmitch87's Avatar
    May 2013
    Boston MA
    I need to do this on my newly acquired gtp, will probably tackle it in a couple weeks (being paid every other week is a huge PITA, but I will need to have it done to pass inspection). Steering the car sucks with a bad pump but Ill manage until then. A couple people told me its a pain to do and you absolutely HAVE to remove the dogbones and tilt the engine. I really dont want to do that, the less I have to remove the better. Is it possible to do it without doing that? The link in the OP is broken.
  6. #26 Re: Power Steering Pump Replacement [*]
    just so you know if your pump is dead, like it was whining, then quit working, if you drive the car, your killing the rack and pinion, and you'll be looking for a rack next.
    and then theres also the off chance the rack is dead and not the pump.
  7. #27 Re: Power Steering Pump Replacement [*]
    May 2013
    Boston MA
    Well, my buddy who I got the car from, drove it with a bad pump for a few months. Now I have to for a couple weeks. Im fairly certain its the pump not the rack, because the pump makes a slight whining noise when I turn. But if Im at a stop and try to turn the wheel, I basically cant unless I give it some gas. Driving down the road its fine, unless its REALLY slow. He said he put fluid in the pump, and it would get low but there was no leak anywhere, so where would the fluid go. He lives and works in town so it wasnt an issue for him (5min drive to and from work for him at most) and I work 15mins away from home. I deff do not want to kill the rack, but it seems like the pump works when I give it gas, so thats what I do when I need to turn. If anyone here thinks its not the pump please chime in!
  8. #28 Re: Power Steering Pump Replacement [*]
    if you cant see the leak by the pump check the rack for leaks, it has to be going somewhere.
    if the rack is leaking, you need a new rack. there should be drops on the ground under your car.
  9. #29 Re: Power Steering Pump Replacement [*]
    May 2013
    Boston MA
    No leaks whatsoever. I honestly think maybe he just topped off the fluid once. Pump don't leak. Rack don't leak. And I have no drips underneath the car. I think the pump is just bad. Its only a 40-60$ part so I'll replace it. If that doesn't fix it then its the rack and I might be in trouble.
  1. Repair Your Power Windows Switch[*]
    By J_Ferguson in forum How To Write-Ups/Tech Tips
    Last Post: 10-19-2013, 01:07 AM
  2. Without power again
    By Rocket468 in forum Off Topic Discussion
    Last Post: 04-21-2011, 12:50 AM
  3. Change Oil Soon Light
    By thermanlee in forum General Tech Discussion
    Last Post: 04-29-2009, 08:47 AM
  4. 2005 Power Steering Pump Seems Thrashed
    By Myoldmopar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-12-2009, 07:28 PM
