Thread: Water in floorboard (Take 2) - The Permanent Fix
Results 1 to 20 of 662
  1. #1 Re: Water in floorboard (Take 2) - The Permanent Fix
    GTX Level Member bronzemist02's Avatar
    Canada
    Quote Originally Posted by 98GTPCALGARY View Post
    I just ordered mine, its $7 and change here.
    Thanks for the write-up Abrasive
    Mine was about the same amount. Well worth it IMO to have a dry floor.
    02 GT: Silverstar ultras, nighthawk platinum 2157s, ngk plugs, champion wires, 6k hid fogs, stainless magnaflows, cleaned tips, 2 10" subs. Finally painted.
  2. #2 Re: Water in floorboard (Take 2) - The Permanent Fix
    Wausau, WI
    Quote Originally Posted by bronzemist02 View Post
    and not to mention all the damage it does to the carpet, floor, anything in your car, and your blower motor, etc.
  3. #3 Re: Water in floorboard (Take 2) - The Permanent Fix
    Toronto, Canada
    Ya my blower fan makes a tick tick tick noise after a big rainstorm caused water to get in there and jam it. and it was only 8 months old replaced by the previous owner , oh well it still works so I will not replace it yet.
    -If only that prev owner had fixed the root cause , oh well
    I have fixed it now using the new deflector , thanks for posting all the pictures and info , I am sure you have helped countless people.
  1. Water in Passenger Floorboard [*]
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 08-31-2012, 07:54 PM
  2. Permanent Water spots?
    By GXPimpin in forum Detailing Tips and Tricks
    Last Post: 10-15-2010, 06:15 PM
  3. Little mishap with water....
    By duane9586 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-10-2008, 10:15 AM
  4. Water proof GenV
    By GR8racingfool in forum Visual/Body Modifications
    Last Post: 03-12-2008, 08:27 PM
