Thread: How to clearance your stock cast bracket for an intercooler and belt BillBoost way
Results 1 to 12 of 12
BillBoost37 How to clearance your stock... 09-11-2012, 08:02 PM
dsmuts Re: How to clearnace your... 09-11-2012, 08:08 PM
BillBoost37 Re: How to clearance your... 09-12-2012, 06:17 AM
jteske88 Re: How to clearance your... 09-12-2012, 06:19 AM
BillBoost37 Re: How to clearance your... 09-12-2012, 06:21 AM
TLSheff Re: How to clearance your... 09-12-2012, 10:37 AM
matt5112 So if you run an eight rib... 09-12-2012, 11:52 AM
blueguy Re: How to clearance your... 09-12-2012, 11:54 AM
CTKGP09 Re: How to clearance your... 02-19-2013, 12:16 PM
BillBoost37 Re: How to clearance your... 02-19-2013, 01:36 PM
98PONTIAC Re: How to clearance your... 02-24-2013, 10:05 PM
BillBoost37 Re: How to clearance your... 02-26-2013, 10:33 AM
  1. #1 How to clearance your stock cast bracket for an intercooler and belt BillBoost way
    The other day I had this thought.. Today talking to a fellow GP'er I bolted a spare bracket to the motor and went to work. 30 minutes total invested to this point.
    The whole premise was.. the belt only catches a little under a 1/2 inch of the bracket. Why not remove some of the excess and slide the bracket over, seemed possible..I went to work.
    Using a 4 1/2 cutoff wheel, then a carbide grinding bit to finish it off a little. Here's the pics.
    Remove your coils, icm and pack mounting plate. May need to put the bracket in a vise. My motor was out already. Then cut in across the bottom to make the area flush with the old area that the pack mounted to and then cut down from directly above to complete the corner.
    Bad angle, but I could see this cleared
    Redrill at least two of the three holes and mount.
    Like I said..this was a quick and dirty prototype to see if it was possbile. Dammit..it's going to work like a charm.
    SuperEasy Easy
  2. #2 Re: How to clearnace your stock cast bracket for an intercooler and belt BillBoost me
    So you grind out the inside of it and move everything over so the belt doesn't hit the coils?
  3. #3 Re: How to clearance your stock cast bracket for an intercooler and belt BillBoost wa
    Bingo. Seems too easy huh?
  4. #4 Re: How to clearance your stock cast bracket for an intercooler and belt BillBoost wa
    Yoga city
    you just now are doing this? i thought you wold of worked teh voodoo earlier on lol
  5. #5 Re: How to clearance your stock cast bracket for an intercooler and belt BillBoost wa
    Why think it up.. all the GP geniuses supposedly already did. Cept..most of the time..I find it doesn't work out.. lol
    Just happened to look at the bracket a little closer the other day. Annnnnd poof.
  6. #6 Re: How to clearance your stock cast bracket for an intercooler and belt BillBoost wa
    I live here. TLSheff's Avatar
    I think I have a spare bracket in a box of goodies that could use some modification. Nicely done Bill
    So if you run an eight rib youre SOL?
  8. #8 Re: How to clearance your stock cast bracket for an intercooler and belt BillBoost wa
    Negative.
    Just keep grinding away till it all falls apart.
  9. #9 Re: How to clearance your stock cast bracket for an intercooler and belt BillBoost wa
    Willoughby, Ohio
    thanks bill, this really was the quick and dirty way to make clearance for the belt, works great!
  10. #10 Re: How to clearance your stock cast bracket for an intercooler and belt BillBoost wa
    Nice to hear that. I haven't had a need to put one into use yet.
  11. #11 Re: How to clearance your stock cast bracket for an intercooler and belt BillBoost wa
    Dec 2012
    Wake forest, NC
    Send it my way I will put it to use lol should be picking a intercooler up this coming weekend
    98 GP GT l67 swapped.......zzp 1.0 pcm, zzp underdrive pulley, dogbones flipped, hot air intake, 17" wheels, straight piped, tinted tail lights
  12. #12 Re: How to clearance your stock cast bracket for an intercooler and belt BillBoost wa
    How can you comment on this and knowing it is on it's way ...then say.. "I didn't look at the pics?"
  1. 04+ Intercooler install?Alternator bracket
    By Explicit_Spade in forum 04+ Specifics
    Last Post: 01-27-2012, 04:35 PM
  2. Gatorback Belt size for stock S/C?
    By SnowDrift in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-01-2011, 03:44 PM
  3. Intercooler on a stock gtp ?
    By boostedgtp13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2010, 11:57 PM
  4. Should I use a stock belt with a 3.5 pully?
    By ncccgolf5 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2009, 08:24 PM
