Thread: FMHE stage 4 install.
Results 1 to 20 of 36
Guest FMHE stage 4 install. 09-29-2008, 03:17 PM
SyntheticShield Re: FMHE stage 4 install. 09-29-2008, 04:56 PM
Guest Re: FMHE stage 4 install. 09-29-2008, 09:41 PM
SyntheticShield Re: FMHE stage 4 install. 09-29-2008, 11:50 PM
GOTIT4CHEAP16 Re: FMHE stage 4 install. 07-05-2011, 08:42 AM
Colossus Re: FMHE stage 4 install. 07-05-2011, 10:56 AM
Scottydoggs Re: FMHE stage 4 install. 07-05-2011, 11:05 AM
matt5112 Re: FMHE stage 4 install. 07-05-2011, 11:04 AM
matt5112 Re: FMHE stage 4 install. 07-05-2011, 11:11 AM
GOTIT4CHEAP16 Re: FMHE stage 4 install. 07-06-2011, 03:00 PM
Scottydoggs Re: FMHE stage 4 install. 07-06-2011, 03:42 PM
z3r0 Re: FMHE stage 4 install. 07-06-2011, 04:56 PM
GOTIT4CHEAP16 Re: FMHE stage 4 install. 07-08-2011, 08:51 AM
glendayle Re: FMHE stage 4 install. 08-28-2012, 06:17 PM
Scottydoggs Re: FMHE stage 4 install. 08-28-2012, 06:30 PM
dsmuts Re: FMHE stage 4 install. 08-28-2012, 06:58 PM
timboku Re: FMHE stage 4 install. 03-04-2014, 08:46 AM
sseilmnop Re: FMHE stage 4 install. 03-06-2014, 05:51 AM
timboku Re: FMHE stage 4 install. 03-16-2014, 01:49 AM
sseilmnop Re: FMHE stage 4 install. 03-16-2014, 07:38 AM
timboku Re: FMHE stage 4 install. 03-16-2014, 03:25 PM
sseilmnop FMHE stage 4 install. 03-17-2014, 12:25 AM
timboku Re: FMHE stage 4 install. 03-17-2014, 12:31 AM
timboku Re: FMHE stage 4 install. 03-17-2014, 01:19 PM
Sven the Sexman Re: FMHE stage 4 install. 03-17-2014, 01:20 PM
timboku Re: FMHE stage 4 install. 03-17-2014, 01:22 PM
Sven the Sexman Re: FMHE stage 4 install. 03-17-2014, 01:23 PM
timboku Re: FMHE stage 4 install. 03-17-2014, 01:40 PM
Sven the Sexman Re: FMHE stage 4 install. 03-17-2014, 01:42 PM
timboku Re: FMHE stage 4 install. 03-17-2014, 01:44 PM
Sven the Sexman Re: FMHE stage 4 install. 03-17-2014, 01:49 PM
jrb1027 Re: FMHE stage 4 install. 03-17-2014, 01:47 PM
timboku Re: FMHE stage 4 install. 03-17-2014, 01:54 PM
jrb1027 Re: FMHE stage 4 install. 03-17-2014, 09:33 PM
sseilmnop Re: FMHE stage 4 install. 03-17-2014, 09:39 PM
timboku Re: FMHE stage 4 install. 03-17-2014, 10:44 PM
  1. #1 FMHE stage 4 install.
    TDCRacing
    Guest
    This is to show how to install a FMHE on your car. This is a stage 4 from ZZP. They said it will not fit if you still run a/c and have the ac condenser installed. I'm about to show you how to make it work.
    Here are some comparison pics of the stage 2 and my new stage 4.
    First take the front bumper COVER and BUMPER off (bumper has 6 bolts)-
    Next remove these tabs as it won't go into place with these here.There is one on both passanger and drivers sides-
    Grind/cutt them off with an angle grinder but be sure not to slip. If you do you will be riding around without a/c untill you get a new a/c condenser(Not sure why the SAFTY glasses are on my head?)-
    They should look like this when your done.Both passenger and drivers side-
    Next you'll have to make the brackets for the FMHE-
    These will slide into the front radiator support chanell and will look like this-
    Next comes the top mounts- make them look like this-
    Next it should look like this when mounted-
    Next notch the lower air dam (corners so it will clear the hoses ect.) with a thick razor blade or dremel
    Put the bumper back on and should look similar to this-
    Put the bumper cover back on.And you're done!!
  2. #2 Re: FMHE stage 4 install.
    Oklahoma
    Very nice write up. Thank you for contributing to the community and taking the time to post this up.
  3. #3 Re: FMHE stage 4 install.
    TDCRacing
    Guest
    Oh no problem, I wish i could have been more detailed with measurements ect. but I was pressed on time. I haven't been around in a while so i figured i better come back with something good so no one bans me LOL
  4. #4 Re: FMHE stage 4 install.
    Oklahoma
    A few more write ups like that and I 'might' be convinced to take you off the probationary ban list.
  5. #5 Re: FMHE stage 4 install.
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    anyone know where i can get those brackets used to mount from?
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  6. #6 Re: FMHE stage 4 install.
    Windsor (ON) Canada
    3 years later........
  7. #7 Re: FMHE stage 4 install.
    those brackets look like they could have been home made, flat stock a drill and a vise and a hammer to make the bends, see all the dings on the sides...
  8. #8 Re: FMHE stage 4 install.
    and a scam 'n ban or two.
  9. #9 Re: FMHE stage 4 install.
    rad is part number CU98, seems like this would be much better than any FMHE.
    http://www.max-boost.co.uk/max-boost...ler_2JZGTE.htm
    Break out the air gun and try it.
  10. #10 Re: FMHE stage 4 install.
    Bowie, MD
    Thanks guys. Why was he banned?
  11. #11 Re: FMHE stage 4 install.
    if you look at the next to last pic it looks like there would be enough room to install a 16" fan set up as a pusher, as now the stock fans are pulling air through 3 radiators.
  12. #12 Re: FMHE stage 4 install.
    Bunnell, FL
    Quote Originally Posted by GOTIT4CHEAP16 View Post
    scammed alot of people on the top 3 gp sites
    iirc it was close to 4.5k on just gpona members
    I'm a Sex Offender
  13. #13 Re: FMHE stage 4 install.
    Bowie, MD
    Damn
  14. #14 Re: FMHE stage 4 install.
    GT Level Member glendayle's Avatar
    Salt Lake City
    Are these pics history?!
    1999 Regal GS Mods-180 tstat; CAI FWI; ubend delete/3"DPCB PLOG; HID fog conversion, 3.5, tint(42%/20%), TK Trans 3.29 gears
  15. #15 Re: FMHE stage 4 install.
    they sure are, and boy am i also upset a bit lol i was going to copy this set up.
    it used a vw radiator ( or similar) and mounted it up in front of the cars radiator. nice and high and right in the path of the grill.
  16. #16 Re: FMHE stage 4 install.
    85-92 vw golf rad with ac I'm pretty sure.
  17. #17 Re: FMHE stage 4 install.
    Donating Users timboku's Avatar
    Montgomery, IL
    I know this is way old but any one have pics or as aother write up on installing the vw rad. While still maintaining ac condenser? Been looking cant find anything.
  18. #18 Re: FMHE stage 4 install.
    Mercer, Pa
    I did VW radiator on Bonneville SSEi.
  19. #19 Re: FMHE stage 4 install.
    Montgomery, IL
    Im gonna go wit the vw radiator. Any pics or how did you reduce the 1 3/16 hose coming out.the rad. to 3/8s for the ic. I cant find any reducer or adaptor?
    Sent from my SCH-I545 using Tapatalk
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  20. #20 Re: FMHE stage 4 install.
    Mercer, Pa
    I remember there was a molded heater hose and then a reducer. It's been 7 years since I installed it. McMaster Carr website is down I will look later.
  1. I/C FMHE Question
    By TDCRacing in forum General Tech Discussion
    Last Post: 09-12-2008, 02:59 PM
  2. ZZP FMHE mounting
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-08-2008, 07:56 PM
