Thread: Radiator upgrade for 97-03 GP's
Results 1 to 20 of 34
  1. #1 Radiator upgrade for 97-03 GP's
    St. Louis
    I'm going to post this since the rads. on these cars like to go bad often for various reasons. Feel free to suggest improvements/add info that I may have missed. It's 1:17am and I've been up since 5:30 yesterday so I may have missed something, lol..
    Since my stock rad. died I decided that while it was out it was a good time to look around for an upgrade. Might as well go bigger/better if it won't break the bank. After digging through some old posts here and a few other sites I found that there is a 1 3/8" core rad. that will swap into any W-body with little modification and loss of room under the hood. This was done on my 2000 GP GT. I don't have headers yet but don't see an issue for any of the guys that do. Also, this will require that you have the 99+ coolant bottle mounted on the pass. side strut tower as the overflow tube is on this side of the rad. For you 97-98 guys there is are threads on this site that detail how to swap over to it. Do a search, it works, trust me.
    The parts list I used is as follows:
    1. Murray Radiator from OReillys (Lifetime Warranty)- 1 3/8" core- Is listed for a 1998 Monte Carlo w/ the 3800. Just choose the HD cooling. Their site lists 3 different radiators. One is the stock 5/8", a 1", and the 1 3/8". Word to the wise would be to bring a tape measure with you when you pick it up so you can measure it in the store to be sure you got the correct one.
    2. 1 gallon of your choice of coolant. Since I run conventional green, that's what I went with.
    3. New radiator cap. Not a necessity but I discovered someone installed a 15lb cap on it, and stock is 16.- $7.99 at Autozone
    4. Dayco LOWER radiator hose from Autozone. Part # C71700- $13.99
    5. New longer bolt for the center of the fan assembly where it bolts to the top edge of the rad. You'll see it when you remove the fan assembly. The stock bolt is a M6x1.00 according to my tap and die set. The replacement I got was 1" longer than stock.
    Now that you have the parts, lets move on to removal/install...
    1. Remove radiator support bars on both sides. One covers the airbox and the other the battery.
    2. Disconnect Battery (both cables) and remove it from the engine bay.
    3. Remove airbox assembly. You can leave the tube on the throttle body but the entire box has to come out. The ECM is inside the bottom half of the box so gently move the wire harness from the side of the box and lay the ECM on the inner body where the airbox was.
    4. Drain radiator into a large container. I didn't mess w/ the petcock, just pulled the lower hose off and let it drain into my pan. Personal preference and a lot quicker.
    5. Remove both dogbones from the radiator core support.
    6. Disconnect the wiring harness from the fans to the main loom. Should be a large gray plug up near the top between the fan shrouds.
    7. Now that the radiator is empty, remove the lower hose entirely, and disconnect the upper hose and move it out of the way of the fans. I chose to leave mine on and just fold it back some. You could also remove it from the thermostat housing as well.
    8. Remove the 3 bolts holding the fan assembly to the radiator. One on each side near the edge, and one in the center up under the edge of the core support. Should be 10mm bolts.
    9. Disconnect the transmission lines from the bottom of the fan. There was a plastic holder on mine that they cliped into.
    10. Disconnect the low coolant sensor harness.
    Once this is completed the fan assembly should be free and ready to come out. NOTE: Remove your oil dipstick and set it aside until you get the fans out and reinstalled at the end as it is possible you may hit the dipstick and crack it like many of them already are. Just don't forget to replace it before driving! I pulled my fans out towards the drivers side. Just pulled up on that edge and worked it to the right and up. It is kind of heavy and can have some sharp edges on it so be careful.
    11. With the fans out, you can disconnect the 2 trans. lines from their fittings on the rad. When you remove the clip for the snap-in style lines be sure not to loose it. A small retractable magnet can come in handy if you loose one. They will most likely end up on the lower air dam or on the bottom of the core support somewhere.
    12. With all lines and hoses disconnected you can now remove the mounts on either side of the tank. There is one per side. Then simply push the radiator towards the motor and lift it out. There are 2 rubber feet on the bottom that you need to save as well once it is out. They are to fit the radiator properly and give it the proper mounting height.
    With the old rad out, now would be a good time to clean out the A/C condenser coil. I used my air compressor to blow it out from the backside. Quite a bit of junk was removed. Just don't bend the fins on the condenser. If any are bent from removing the radiator then straighten them out.
    Now, onto the install of the larger radiator.
    Here are some pics to help illustrate..
    Side by side comparison of the old on left and new on right
    Here is a shot of the new radiator core measurement
    13. Transfer the rubber mounting feet to the new rad. May need some WD-40 or something to help install. Remove the 2 trans. cooler line fittings from the old rad and install on the new one. I used some teflon tape on them to ensure no leaks. Remove and clean the low coolant sensor from the old rad. Notice in the pic below that the new rad. has the coolant sensor port on the side of the tank, not the backside. Mount it so the plug is facing UP as shown in pic 2 below.
    Now you can install your new radiator. It drops into the original space. Install the 2 metal clips that are used to hold the fans on. One per side. Make sure the rubber mounts are all the way in the core support at the bottom. Once in, reinstall your side mounts to hold it in place.
    14. Reinstall the 2 clips to the transmission lines if you have that style. I chose to wait to reinstall the lines until I had the fans back in place. You can do what you feel comfortable.
    With the lines back in place, reinstall the fan assembly being carefull NOT to bend up the fins on your new radiator. Bolt it down on both sides and use the longer top bolt.
    Reinstall the upper radiator hose. Reassemble and install the airbox/ECM. You can now put the drivers side core brace back into place.
    Now I'm sure you've noticed that the lower hose mount on the new rad. is angled inward towards the motor, not straight out like your stock unit. This is where the new lower hose comes into play. Test fit the new hose to be sure you have it at the proper angle and not upside-down. It should be pretty obvious once you look at it. Cut a 1/2" off the end that connects to the waterpump outlet. This will ensure that the bend at the bottom of the hose is not too severe and does not create a restriction in the system. This also allows safe passage of your A/C compressor pulley and the belt. This is a cut-to-size hose, so cut however much you need, or none at all.
    With all hoses and lines back in place, reconnect the fan assembly harness. You can now also reinstall the battery. I had to unbolt and swing the fuse block out of the way a bit to get enough clearance to snake the battery back in. It is tight but will fit. Make sure the hold down is completely removed for this. Once in replace the hold down and reinstall your brace.
    Reinstall the dogbone mounts to the core and use a ratchet strap or the like to rock the motor forward enough to get the bolts back through.
    Check over all your work to be sure there are no loose ends. Especially check the airbox as mine was being a PITA and wouldn't go back together correctly at first. If everything looks good then reconnect your battery after cleaning both the terminals on the battery and the cable ends.
    Fill up your new radiator w/ the gallon of coolant and then fill the coolant bottle with water. This should give you the proper mix once you get done topping it all off. Then simply start the car and let it warm up to temp w/ the heat on full blast. Once the thermostat opens then use the bleed screw on top of the thermostat housing to bleed out the air. Once you see a solid stream of coolant then it should be good to go. Leave it run and check for any leaks. If none are found then go take a drive to get everything filled. Let it cool off overnight and then check the coolant level again in the rad. and the bottle and top off as needed.
    Below is a completed shot from top to show clearance between the fans and stock N/A exhaust. And no, I did not measure it, but can if someone requests it.
    FordMan77
  2. #2 Re: Radiator upgrade for 97-03 GP's
    I used the CU1518 from a 95 monte, 1.25" core.
    Stock lower rad hose doesn't fit well.
    71700 is the stock replacement lower rad hose for our cars.
    For the 95 monte core the fan shroud needs to be trimmed to sit flush again.
    my 2001 stock trans cooler fittings did not fit into that rad either.
  3. #3 Re: Radiator upgrade for 97-03 GP's
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    i got my oversized radiator from wbs and i love it
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  4. #4 Re: Radiator upgrade for 97-03 GP's
    Cambridge, Ontario Canada
    Any problems with an oversized rad & headers?
    2005 E55 - stock
  5. #5 Re: Radiator upgrade for 97-03 GP's
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    Oreillys has this rad for $135
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  6. #6 Re: Radiator upgrade for 97-03 GP's
    Quote Originally Posted by Elite6 View Post
    Depends if you had the issues before hand.
  7. #7 Re: Radiator upgrade for 97-03 GP's
    Some headers come real close to the fans with the stock rad. If they were not hitting that would not be a problem. But getting a thicker rad may cause contact. Just wondering if its that close for anyone?
    2005 E55 - stock
    My condensor is gone, might be proving some extra clearance. Regardless i have no issue there.
    I didn't have issue even though they were close just can't have shortened dog bones. Had to go back to stock
    Sent from my iPad using Tapatalk HD in this stupid country Afcrapistan...
    SMGPFC #77
  10. #10 Re: Radiator upgrade for 97-03 GP's
    GT Level Member fisher580's Avatar
    Jan 2012
    Dyersville, Iowa
    mine it if the motor is rocked forward, 10k miles and no proplems yet, btw i hace Ebay headers and stock 01 gtp rad
    2001 Grand Prix GTP Coupe - Black-SOLD
    -SOLD
    2006 Grand Prix GXP - That Purplish dark red color
    -FWI, DiabloSport Trinity, and Trans. Cooler - - 6.8 @ 208 mph LOL
  11. #11 Re: Radiator upgrade for 97-03 GP's
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    how did those ebay headers work for you exatly what had to be done to make these fit seeing as how noone has posted a how to
  12. #12 Re: Radiator upgrade for 97-03 GP's
    THERE ARE LITERALLY TENS OF THREADS ON THIS SAME STUPID TOPIC.
    do some of your own work for once.
  13. #13 Re: Radiator upgrade for 97-03 GP's
    GT Level Member GPTAFan's Avatar
    Sep 2012
    Maryville, Illinois
    I sort've upgraded my radiator, i have an 2002 gt, and took a radiator from a 98 gtp which was about twice as thick.. the tranny line connectors that screwed into the radiator were bigger on the stock radiator than the 98, so i used a pick to pull the small clips outa the connectors. and swapped em. thankfully it worked. there would be more clearance with this radiator.. but my core support for the radiators bent in :P so i still only have enough room to slide my hand down in there.
    didnt need to do anything different than the tranny line connectors. everything else was where it needed to be
    GT Level Member Utter99's Avatar
    Warsaw indiana
    Monte rad and headers worked for me still have half inch clearance
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  15. #15 Re: Radiator upgrade for 97-03 GP's
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    Any noticeable cooling difference? I imagined a few degrees cooler, especially on the highway if any benefit at all.
    Thought about getting a lil thicker Radiator, but with TOGs and shorter dogbones I came to realize that it may not fit or at least will be cutting it pretty close. Maybe if I went back to stock dogbones it may be possible, but then clearance might be an issue(like for reaching spark plugs, wires, cleaning/degreasing, and most importantly the less space may restrict the fans from performing at their most efficient potential.
    A new stock Radiator, good courtesy flush, washing down the fans real good, cleaning the condenser of debris, new hoses, fresh coolant, and a top off of PURPLE ICE coolant additive may be enough cooling efficiency you'll need to maintain them temps.
    Still feel like im missing out without that bigger Radiator, LOL.....
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  16. #16 Re: Radiator upgrade for 97-03 GP's
    Never Never Land
    Did some checkin around on pricing. I went on O'reily's first since that's where you said you got it. I believe the one we're looking for has a part number of 432387. It's about 135 on their site. So I hopped on Amazon. It was listed at 150 under a Proliance brand with the same number. So I checked trusty Rockauto. Went under 1998 Monte Z34 and found the same part number again, except this time under a Vista-pro brand. All 3 looked indentical and all three claimed to be the 1 3/8" core for HD cooling for a 98 Z34 Monte. Rockauto's price is 103 for that radiator.
    So any of you looking to do this, i'd suggest ordering it from RA. Shipping is about 15 bucks which puts you at about 120, and that doesn't include the 5% discount. This upgrade is easily do able for under 150 bucks ordering the core from RA.
  17. #17 Re: Radiator upgrade for 97-03 GP's
    Buffalo
    My results and thought exactly
    Also I have an 03 i think 00-04 are SOL with the transmission cooler line fittings being too big for the radiator
  18. #18 Re: Radiator upgrade for 97-03 GP's
    Often you can use the fittings that come with the new radiator to mitigate teh issue.
    Found out that not all the W body's have the same fans. Assemble your fans on the new radiator out of the car and check fitment. Some fans are closer to the core and changing the size of the core might put the center bolt of the fan into the radiator.
    Buffalo
    Nothin comes with that Part number radiator.
  20. #20 Re: Radiator upgrade for 97-03 GP's
    Apr 2011
    Tally, FL
    found that out the hard way
  1. Radiator upgrade how-to
    By FordMan77 in forum General Grand Prix Discussion
    Last Post: 07-22-2012, 01:06 AM
  2. Radiator help
    By Jordan Flowers in forum General Grand Prix Discussion
    Last Post: 06-22-2012, 09:54 PM
  3. Headlight and FogLight Upgrade (to upgrade to HID or not?) Please Help???
    By Michigan04GrandPrix in forum Visual/Body Modifications
    Last Post: 04-20-2012, 12:53 PM
  4. Cheap 1-3/8" Radiator upgrade for your 97-03 Grand Prix [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 08-13-2010, 12:26 PM
  5. Upgrade, 1-3/8" Radiator locally for most folks...
    By Iron Indian in forum Shops and Community Heroes
    Last Post: 10-26-2008, 10:24 PM
