Thread: How to replace front hubs
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 108
  1. #1 How to replace front hubs
    St. Louis Mo.
    I have gotten quite adept at taking my front end apart of late due to a blown passanger side CV boot, and then a wobbly driver side half shaft, so I figured it would be a good time to take some detailed pictures on how to remove you hub assembly from the front wheels of our GPs.
    1. Loosen the lug nuts on the wheel to which the hub needs to be replaced. But to do it while it's still on the ground and not jacked up in the air. (obvious one there )
    2. Jack up the car and use jack stands to support sides of the frame underneather the engine. I also go a step further and leave the jack still still propped up against the front cross member of the frame. That way if one of the jack stands fail, the car won't fall over on ya
    3. Once jacked up, remove the lug nuts completely from the wheel and take off the wheel.
    4. The next step is to take axel nut off the axel. There are several methods to do this. I used this method below.
    The old ratchet extension stuck in the brake rotor vein trick. I used a 36mm socket with a nice long breaker bar to get the axel nut started. Once loosened I was able to undo the rest with just the socket wrench and then finally my fingers at the end.
    5. Once you have the axel nut off, you need to remove your brake caliper AND the caliper bracket from the back of the knuckle. There are 2 bolts you need to take off, the bolts require a 15mm socket. Remember, you only need to remove the 2 bolts securing the caliper bracket. The caliper is obviously connected to the bracket so you do not need to undo those bolts. As shown below.
    6. Once you have both bolts out, you need to store the brake caliper out of the way. I find the bunge cord method works quite well. A coat hanger would also work, but its a bit more time consuming having to bend and shape the thing.
    7. After you remove the brake rotor from the hub, you will have the hub assembly staring you dead in the face.
    8. There are 3 bolts securing the hub to the knuckle of the car. Remember to disconnect the ABS plug before removing the hub from the knuckle. As shown below.
    9. Once the ABS connection has been unplugged, you can remove the 3 bolts securing the hub. The bolts are 13mm in size. One at the top, and two at the bottom on both sides of the bottom part of the knuckle.
    The Top Bolt
    The bottom front bolt
    The bottom rear bolt
    10. Once you have all 3 bolts removed. You can safely remove the hub from the knuckle and axel.
    You should only have 2 bolts removed from your brake caliper and 3 from the hub itself.
    Once you have replaced your hub, you go backwards in order 10 through 1. I use lock tite, the red stuff, to rescure the bolts inplace. And I use anti seize on the axel nut when I put the nut back on. The driver side requires 118lbs of torque and the passanger side requires approx 108lbs of torque to tighten.
    James Shafer
    St. Louis MO
  2. #2 Re: How to replace front hubs
    Oklahoma
    Very nice. Good work.
  3. #3 Re: How to replace front hubs
    SE Level Member trenaro's Avatar
    Feb 2009
    KC
    Is the axle nut a different size on 03? I have an 01 and its 36mm.
  4. #4 Re: How to replace front hubs
    St. Louis Mo.
    I guess it must be if your's is 36mm. Past that I can not say. I thought they were pretty much standard?
    James Shafer
    St. Louis MO
  5. #5 Re: How to replace front hubs
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    i just changed my drivers side wheel bearing on my 98 and the axle nut was definitely bigger than 23 mm. i think it was 36.
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  6. #6 Re: How to replace front hubs
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    wow. that looks much more easy then other write ups i have seen for this project
  7. #7 Re: How to replace front hubs
    St. Louis Mo.
    Sorry for taking so long to correct the axle nut size. I don't where I was getting 23mm from My apologies
    James Shafer
    St. Louis MO
  8. #8 Re: How to replace front hubs
    Donating Users mystic231's Avatar
    Michigan
    Thanks for the write-up with the excellent pictures. Makes it much easier to jump into something you haven't tried before.
    I would add to this that GM recommends replacing the (3) hub mounting bolts when changing the hub:
    Caution: These fasteners MUST be replaced with new fasteners anytime they become loose or are removed. Failure to replace these fasteners after they become loose or are removed may cause loss of vehicle control and personal injury.
    The hub mounting bolts are GM Part No. 11570580 and come with red loc-tite already on them. My local "stealership" charged me $3.51 each plus tax. The new hub bolts get torqued to 96 lb ft.
    The two bolts on the brake caliper bracket get torqued to 133 lb ft.
    The 36mm wheel driveshaft nut gets torqued to 159 lb ft, not 118 as mentioned earlier.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  9. #9 Re: How to replace front hubs
    Apr 2009
    Indiana
    Thank u so much i did my pass side and i took off the ball joint and axle and tie rod didnt know it was that easy
  10. #10 Re: How to replace front hubs
    SE Level Member Morris 04 GTP's Avatar
    May 2008
    North Eastern CT
    My axle nut on my 04 was 34mm, Now that I know that I'll just go buy one for the future instead of renting one from advance.
  11. #11 Re: How to replace front hubs
    Kansas
    Where can you get new hubs?
    SOLD 1999 GT Silvermist TS
  12. #12 Re: How to replace front hubs
    Wooster, Ohio
    rockauto.com, local parts house...dont go cheap or you'll regret it later. Make sure they have a warranty
  13. #13 Re: How to replace front hubs
    Richardson, Tx
    I need to do this on my wife's '01 GTP. I've looked at RockAuto and there appears to be more than one design for the front hubs. How do I know which one is correct for her car?
    TIA.
    Rob
  14. #14 Re: How to replace front hubs
    MT
    Quote Originally Posted by AT7WE2 View Post
    TIA.
    Rob
    If I had to guess the only difference would be with or without the abs tone ring. Abs ones cost a little more but are required if you want abs (obviously)
  15. #15 Re: How to replace front hubs
    MT
    Have any of you guys had a problem getting the hubs off an 04? (the 04's are a 34mm nut btw)
    I had my brakes off, axle nut off, and a 2-ton gear puller on the hub (wrapped around the back of the hub with the "bolt" of the puller pushing on the axle) and I stripped out the puller before the hub let loose.
    I've done hubs on my K1500 chevy before and all I ever needed to get the axle shaft out of the hubs was a quick smack with a hammer. I thought this would be easy but so far I've wasted an entire afternoon and a $50 puller on the project.
    Also, hubs were roughly $130 from 0'reileys for the better ones with a 1 year warranty.
    To make it even more complicated I need to leave for a trip by sunday at the latest.
  16. #16 Re: How to replace front hubs
    Dec 2008
    London, Ontario
    Quote Originally Posted by chevy man View Post
    Mine was the original factory hub when i changed it a couple weeks ago..it was seized on there so tight...if you can use like an air chisel on it, do that...otherwise smash the hell out of the back of the hub to get it to seperate
  17. #17 Re: How to replace front hubs
    Feb 2010
    Chugiak Alaska
    I too had a bunch of issues removing the hubs on my 04. I started by whacking them with a big hammer, didn't work. I then used a gigantic slide hammer that attached to the lug studs, rapped on it a few times, and I thought my axle was gonna fly out. That knocked it loose enough that I could use a fairly large punch in the center of the axle spindle and release the hub. Now my problem lies in the passenger side where one of the bolts has rounded off..........anyone have any suggestions, its the forward most knuckle to hub mounting bolt.
  18. #18 Re: How to replace front hubs
    Nebraska
    Quote Originally Posted by ZeroAK View Post
    We just did a set on a 99 Regal. If you round the bolt you'll have to cut through it with a SawZall or grinder with cutoff wheel on the outside. Just cut down through the bearing and avoid the knuckle. The stealership charged me $7 for a bolt. One of mine was stubborn, the other easy. Forget the flange puller or slidehammer. If it's stuck use an OTC 7394 or similar with an impact gun. Its built like a tank, no worries..............
  19. #19 Re: How to replace front hubs
    Charles City, IA
    Need a twist socket.
    SMGPFC Two Nipple General
  20. #20 Re: How to replace front hubs
    GT Level Member pontiacGTP123's Avatar
    stanford Ky
    I hate changing hubs, I just done mine yesterday as a matter of fact. Its not really hard its just aggravating.
    05 gtp- k&n open cone, intense tune, cat delete
    99 gtp- sold
    97 chevy 2500 diesel- heath turbo master, custom cai, 4" straight exhaust
    70 chevy c10- 6.0 swapped, still a project
  1. Should I and what to replace??
    By torq455 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-28-2009, 08:13 PM
  2. Axles, hubs and Halos - oh my!
    By MnRedGP in forum General Tech Discussion
    Last Post: 02-08-2009, 02:08 PM
  3. what do i need to replace
    By guy87 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-27-2009, 07:30 PM
  4. How Do I Replace the FRP?
    By TZ250 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-27-2008, 11:07 PM
  5. Wheel Bearings/Hubs
    By bcrosby51 in forum General Tech Discussion
    Last Post: 09-15-2008, 01:49 PM
