Thread: HOW TO: Hand polish engine parts
Results 1 to 20 of 27
  1. #1 HOW TO: Hand polish engine parts
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    Originally found on :
    Code:
    Accord Tuner
    Original Link
    Code:
    http://board.accordtuner.com/showthread.php?t=341
    Sorry for not having any pictures i plan on doing this over the weekend so i will post some pics
    How to hand polish aluminun engine parts
    Things you will need
    1.320 grit sandpaper
    2.800 grit sandpaper
    3.1000 grit sandpaper
    4.1500 grit sandpaper
    5.2000 grit sandpaper
    6.Pack of multi grade steel wool
    7.1 Can of Eagle 1 Nevr dull polish
    The first step is to clean the aluminum part and begin sanding the part with 320 grit sandpaper.
    After the part is completly bare you will be ready to begin the polishing.
    Properly sanding the part with the 320 grit paper and applying never dull the part will appear to have a polished look, but dont stop there!
    Now that the metal is polished with 320 grit paper you are ready to move on to 800 grit paper, sand with 800 until the scratches from the 320 are polished out.
    Between changing paper I always never dull the part, the never dull make the process much simpler.
    You can use the steel wool to clean the metal and remove any stains the metal has in it.
    After you sand with the 800 grit paper you progressivly move up it sandpaper. Each paper will further the shine of the aluminum.
    Nevr dull is an extremly great product and I would not polish anything without it. Without never dull you will not get a show quality shine. Good Luck Polishing takes a lot of time.
  2. #2 Re: HOW TO: Hand polish engine parts
    SE Level Member kassel98gt's Avatar
    Howell,MI
    good post gonna try this soon
  3. #3 Re: HOW TO: Hand polish engine parts
    Aug 2008
    KCMO
    sounds good. when are some pics gunna be posted?
  4. #4 Re: HOW TO: Hand polish engine parts
    Jul 2008
    Germantown, Maryland
    did you use the steel wool first?
  5. #5 Re: HOW TO: Hand polish engine parts
    St. Louis
    Quote Originally Posted by Quicklynx View Post
    yes i used steel wool first
  6. #6 Re: HOW TO: Hand polish engine parts
    GT Level Member pontiacGTP123's Avatar
    stanford Ky
    what are some easy removable parts that are good for this?
    05 gtp- k&n open cone, intense tune, cat delete
    99 gtp- sold
    97 chevy 2500 diesel- heath turbo master, custom cai, 4" straight exhaust
    70 chevy c10- 6.0 swapped, still a project
  7. #7 Re: HOW TO: Hand polish engine parts
    St. Louis
    the first thing that i tried this one was my cross mounts, and i am going to end up trying it on my top motor mounts once i get some free time, those are about the easiest things to take off
  8. #8 Re: HOW TO: Hand polish engine parts
    Quote Originally Posted by stlmo_gtp View Post
    These are steel parts. Your "writeup" was on aluminum. I am curious to see pics of your hand polished steel parts.
  9. #9 Re: HOW TO: Hand polish engine parts
    St. Louis
    Quote Originally Posted by GTPrix View Post
    you can polish just about anything with enough time and a little hard work.
    Picture is not mine found it over on ClubGP
  10. #10 Re: HOW TO: Hand polish engine parts
    Wichita
    How hard would the s/c be to do?
  11. #11 Re: HOW TO: Hand polish engine parts
    St. Louis
    i personally do not know, but from what i have heard it can be a pain, and it takes alot of work
  12. #12 Re: HOW TO: Hand polish engine parts
    Wichita
    Darn..I was gonna do both my s/c's and sell one of em. Figured maybe i'd get a lil more out of it if it was polished.
  13. #13 Re: HOW TO: Hand polish engine parts
    Banned - Busted For Scamming
    Feb 2009
    Im currently doing one, its alot of work, be prepared. I have about 3 hrs into it and about 1/4 of the way done.
  14. #14 Re: HOW TO: Hand polish engine parts
    Wichita
    Argh. Not prepared for that much more work. Havent even got the new engine in yet.
  15. #15 Re: HOW TO: Hand polish engine parts
    GXP Level Member
    Theworld
    Wouldn't polishing steel make it subject to more heat?
  16. #16 Re: HOW TO: Hand polish engine parts
    SE Level Member 2k6GT's Avatar
    Troy
    That looks coated not hand polished.. looks great though
  17. #17 Re: HOW TO: Hand polish engine parts
    Oct 2008
    Northern Illinois
    Quote Originally Posted by 2k6GT View Post
    Coated with what??
  18. #18 Re: HOW TO: Hand polish engine parts
    GT Level Member Will5600's Avatar
    subs of chicago
    that looks sweet
  19. #19 Re: HOW TO: Hand polish engine parts
    anyone done this to the hipo 5 wheels my hipo 5s on my GP are definatly not so hipo think im gonna start doing this to my wheels
  20. #20 Re: HOW TO: Hand polish engine parts
    May 2008
    McHenry IL
    powercoated??
  1. DIY: How to polish engine parts
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 08-08-2009, 06:05 PM
  2. INFORMATION Pledge Dusting Polish As A Engine Bay Detailer
    By SyntheticShield in forum Detailing Tips and Tricks
    Last Post: 06-29-2009, 06:15 AM
  3. Engine bay detail parts questions...
    By Iron Indian in forum Visual/Body Modifications
    Last Post: 07-12-2008, 11:26 PM
