Thread: How to: Replace your broken ol' sway bar or just upgrade it (97-03)
Results 1 to 6 of 6
Jakescoots How to: Replace your broken... 08-03-2012, 04:13 PM
matt5112 Re: How to: Replace your... 08-03-2012, 04:46 PM
Jakescoots Re: How to: Replace your... 08-03-2012, 06:48 PM
matt5112 Re: How to: Replace your... 08-03-2012, 06:56 PM
mac54 Re: How to: Replace your... 11-04-2012, 07:39 PM
Jakescoots Awesome, glad it helped out.... 11-05-2012, 08:35 PM
  1. #1 How to: Replace your broken ol' sway bar or just upgrade it (97-03)
    GT Level Member Jakescoots's Avatar
    Spring Lake, Mi
    So you may notice that your car has excessive body roll or your sway bar has broken and it probably looks like this
    You should have all this to completely put it together
    Now the first thing to do is undo the links or if they are seized up, cut 'em off!! They are a 13mm socket
    Then undo these (15mm) the drivers side has gas and brake lines in the way, so you may want to get a flex socket joint thing
    Pull out the bar and we have this, because race car
    Now put the new bar in, it takes some wiggling and patience and maybe turn the wheels so it falls into place
    Put the links together in this order
    Now re-bolt the bushings and bracket back into place (15mm again) and then tighten the links down so there is about 1.25-1.5" of threads showing (13mm)
    You're all done now, congratulations
    Does removing the spare count as weight reduction?
    Badges on a car are just advertisements....Everyone already knows what it is. And if they dont, its a mystery. People like mysteries.
  2. #2 Re: How to: Replace your broken ol' sway bar or just upgrade it (97-03)
    Use moog bushings and end links for a more sporty feel.
    Dorman ones are pretty soft, intended for the typical daily driver.
  3. #3 Re: How to: Replace your broken ol' sway bar or just upgrade it (97-03)
    Spring Lake, Mi
    Thanks for the input Matt!
  4. #4 Re: How to: Replace your broken ol' sway bar or just upgrade it (97-03)
    NP, Nice write up guy.
  5. #5 Re: How to: Replace your broken ol' sway bar or just upgrade it (97-03)
    Lasalle Ontario
    Used this last week. Very good! Along with wiggling and patience about a foot of rope through the end of the bar will get it over the last hang up when you can't get any leverage with your hands.
    Spring Lake, Mi
    Awesome, glad it helped out. Hopefully soon I can do a how to to swap the 04-06 style arms to 96-03
    Etched into the Internet by me from tapatalk
  1. ABS problem and a broken sway bar... Oh what a fun day
    By ronmexico in forum General Tech Discussion
    Last Post: 04-15-2012, 11:25 PM
  2. cost to replace a sway bar? Do these crack?
    By andremike in forum General Tech Discussion
    Last Post: 12-26-2011, 01:19 PM
  3. Replace front sway bar bushings w/ GTP on ramps?
    By Joe942 in forum Brakes/Suspension/Chassis
    Last Post: 09-27-2011, 08:00 PM
  4. Sway bar broken
    By skibender in forum General Tech Discussion
    Last Post: 01-20-2011, 07:23 PM
  5. How safe is it to drive with broken sway bar
    By blitz217 in forum Brakes/Suspension/Chassis
    Last Post: 12-09-2008, 01:28 PM
