Thread: How To Install ARP Head Bolts by Farnsworth
Results 1 to 20 of 48
  1. #1 Re: How To Install ARP Head Bolts by Farnsworth
    Wichita, KS
    This:
    is what GM calls for during a rebuild.
    Kinda pricey, so that's where my suggestion comes into play for a good solid alternative.
    Use what you want to, I merely did the step by step write up cause many were using the molly lube on both ends of the bolts and wondering why they were leaking.
    Also, some were using Teflon paste, that was only rated up to 100 some degrees, for your common house hold plumbing repairs. Your engine operates a little hotter than that...so once it reaches that temp. the Paste turns soft again, and allows leak by. Then you have coolant leaking out side the engine, as well as in.
    Just saving people headaches, Heads are one job I prefer to do right the first time was my whole reasoning behind it.
    ~F~
  2. #2 Re: How To Install ARP Head Bolts by Farnsworth
    GT Level Member tylerbinski's Avatar
    Canada
    BUMP
    totally stuck tryng to decide to use teflon paste or teflon tape
    ZZP says tape
    Farns or Gr8racing says no tape, teflon paste, permatex high temp thread sealant.
    well.. can we have a vote here?
    I used GM Teflon Pipe/Thread sealant with PTE last time and loaded it on the threads.. but i suspect they were leaking so i am removing all head studs and want to do them over again.
    i think i am going to use tape this time.
    '04 BLK GP - .. Turbo :P
    GTP SIC - '02GTP | XP Cam | Intercooled Turbo Kit | Cutout....Fire mod 9/11
    GTPSIC '02 | Twin charge, XP cam et
  1. ARP Header bolts
    By Sabrewings in forum General Tech Discussion
    Last Post: 07-29-2008, 01:57 PM
  2. S/C Bolts ?
    By Meemperor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2008, 03:18 PM
  3. ATTN Farnsworth - tool info needed
    By IndeedSS in forum General Tech Discussion
    Last Post: 03-14-2008, 10:54 AM
  4. camber bolts
    By nemesis in forum General Tech Discussion
    Last Post: 02-29-2008, 05:10 PM
