Quote Originally Posted by Jteske88 View Post
And also the three wires you cut should never ever be hooked together 2 are posited and one is a ground. Looks like you have audio ccommon(-) to audio right (+).
all i did was cut off rca's. so the 3 wires that I cut don't get hooked back together? they just attach to the new cable into the harness then plug in? in the picture my audio common is connected to audio common bc i thought i had to connect the wire itself back after cutting it in order to attach to the rca wire.
