why would i have only had one side working? because the wires in the cord were too thin? idk what went wrong
http://i1254.photobucket.com/albums/...008_141853.jpg
would this have worked?? I'd just need a longer aux cable obviously
just thought of something....I have a module connected to my rear speakers for my amp/subs, I thought I seen an extra set of rca's on it. would that have worked?
You need to re read this thread from post number one. I can't see how you are having an Issue But let me try to explain It again
1. Two ways to tap in. At the small (not big) connector on the back of your radio. Or the xm receiver in the left rear of the trunk.
2. Three wires you will tap into. Note there are ONLY the 3 you need at the back of the radio connector.
3. There are 4 wires from your set of rcas left has 2. Right has 2. NOTE: Ignore the foil or bare wire if your rcas have them they do nothing for us at the moment.
4. Every set of rcas is constructed different I'm sure. My set was made by stinger. I opted for a short set of 3ft since I am using the radio connector instead of the xm receiver. I simply cut the ends off ONE side. Left was yellow for positive. And right had a red for positive. Both sides have white they are the common ground for the audio. You hook BOTH white wires together and then attach them to the black/white wIre. Hook your left to positive wire(mine was yellow) to brown/whIte. and your right positive (mine was red) to green/white
4. Now your one end of rcas should be attached the car. The other In your hand with the left and right rcas untouched.
5. I personally used barrel connectors (female on both ends) to attach (see pic) these 6ft male rcas to 3.5mm headphone jack.
Your other option would be just get a female rca ends to 3.5mm jack.
That's it.
http://img.tapatalk.com/d/12/10/09/jyramuze.jpg
Sent from my Galaxy SIII on Tapatalk 2
That helps out thanks. On my xm receiver I was using the long harness, wasnt sure how to get the small one off. I think the small one has less than 6 wires? I gotta get a new set of rca's now, probably the walmart brand.
or was the small connector only described for the radio and I was using the proper harness on the xm?
i dont see how you cant follow directions, there is more than enough info here to get the job done easily. go back and read cause all your doing is asking questions and its all in black n white.
The small plug is where the 3 are at on the radio. the only 3 u need Is In that plug. You can noticablly see the difference the big plug twice the size of the small.
at the receiver I haven't looked but there are no duplicate wire colors on either plug. Those 3 colors are the ones your usIng. Don't worry about what pin or plug just use those 3 wires.
i am pretty sure the xm reciever has just antenna on it and the plug
Yeah I think I was using the right wires then. I must have had a ****ty cable then. the antenna is the cable i couldnt get out lol.
I'll have to get a new set of rca's and try again
Thanks bud. Worked out perfect for me. Just had to follow the directions and connect the grounds to the audio common.
Do we leave the wire coming from the connector unhooked from the spliced wires? Thats what I was seeing in one of the pictures you posted. i'll probably go pick up the sosche rca's in the car audio at walmart.
no its needs to be connected, i was jsut showing process, if you read you will see you need the 2 positives hooked up and the 2 grounds from rcas to the audio common ground
On the diagram it shows audio common is pin 10(tan). But you keep saying ground which is 9(black).
This is the only part I think that is confusing. I've done some electrical work in the past, hooked up sound systems over 20 times, but this part seems to be giving me issues. Any idea also where I might be able to get a 3.5mm jack so I can just run the aux cord straight from the trunk?
thanks!
common is a ground, if you done electrical you would know the terms, the black ground is the ground for the power to the box, you need the common audio ground, both grounds different purpose. and if you cant follow directions you shold stop, this is getting old man, been told by couple of us and ive offered to do it.
well it makes sense now. the audio ground is the tan one where as i've been trying to use the black one. I'm gonna try it one more time and if I cant get it then I'll be contracting some help lol. The first time I tried it I was using the audio common but not the green wire at all. FAIL lol.
This cable says its 22gauge so I assume thats sufficient enough? I know you said you used the rca's from walmart but how were the wires in it? sosche was it?
Thanks
Amazon.com: PREMIUM 25FT 3.5mm Stereo Male to 2RCA Male 22AWG Cable - Gold Plated: Electronics
i dont think cable is gonna be an issue, i have a low quailty in mine and is just fine., the wires were thin, thats why i soilderd them for a good clean connection.
im thinking about using crimp connections, I hate soldering. I'll probably just get that cable i posted in the link so I dont have to worry about the other end of the rca's. plus it'll cost about the same as a walmart rca.
I'll probably do it this weekend then. if the cable gets here in time.
remebre leave the heaphone jack on it, and only cut the l+r rca ends off,
it was either 15 feet or 35 feet for a cable to get here by saturday so I figured better to be too long than too short. Looks like pretty good quality too.
yeah i actually had rcas' laying around and thats whats actually hooked up to the box and i ran the 20fter to the centerconsole where the headphone jack is now. and longer is always beter
