Thread: How to tell if you have the GOOD Lower Intake Manifold gaskets.
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
  1. #1 How to tell if you have the GOOD Lower Intake Manifold gaskets.
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    So this probably isnt the best thread but i'm just hoping that for those who arent sure if they have the good gaskets either before or after they buy a car with the 3800 engine, they will be able to see this and maybe get an idea.
    The lower intake manifold gaskets are known for going bad. And if you replace them with what was on there it will happen again. So what you want to do is replace them with the newer design which are the metal/aluminum kind. The originals are like a rubber/plastic kind. heres a pic and a little bit of info from rockauto.com.....More Information for FEL-PRO MS98014T
    So when looking at the engine to see what kind you have, you have to look where the LIM meets the head of the engine and you can usually tell if the engine is clean and you have enough light.
    In this picture just to the right of my finger tip you'll kind of see two layers of silver the middle layer is the actual gasket where the top is the LIM itself and the bottom which is kinda brown is the Head.
    the next picture shows an angle looking right down at it where you can kind of see it above the fuel injector which is the tan piece.
    if a mod or someone with a program wants they can take the pic and maybe draw an arrow so you can tell a little easier where its at.
    but its real easy to tell once you become familiar with exactly what you're looking at. all you have to do is remove the engine cover and take a peak at the areas shown above. if you're getting ready to buy a vehicle with the 3800, CHECK FOR THIS. if you arent handy this is a 6-800 dollar job at some dealerships and/or auto shops.
    quick looks at the difference between the two
    here you can see where the leak was. it was a small raise at the bottom of the square and it was actually in two squares and on each gasket so a total of 4 spots where it leaked.
    so i hope that helps someone. feedback and additional things are of course welcome. please dont knock this thread too hard as i'm only trying to help people out as best as i can. especially those shopping around and possibly getting themselves in a bad situation.
  2. #2 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    May 2008
    Winnipeg, MB
    when did the newer lim gasket start being used?
    2007 Pontiac Grand Prix
  3. #3 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Charles City, IA
    SMGPFC Two Nipple General
  4. #4 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Nov 2010
    Illinois
    yeah 05 is when the newer gasket came OEM/stock with the car.
  5. #5 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Charles City, IA
    But they still leak.
  6. #6 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Nov 2010
    Illinois
    right. theres no replacement for any car where a problem will never happen again. the new ones just last a WHOLE lot longer.
  7. #7 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Thumbs up blaine!
  8. #8 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Nov 2010
    Illinois
    thanks man!
  9. #9 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    there is also a grey/teal set that are a revised set as well.
  10. #10 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Nov 2010
    Illinois
    Thanks for the input bio
  11. #11 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Grand Island, Nebraska
    I have a white set i got from WBS that has like green rubber, is that right? they werent shiny like that.
  12. #12 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
  13. #13
    Buffalo
    Zzp is metal with teal green
    Ac delco is metal with black
  14. #14 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Nov 2010
    Illinois
    fel pro is also metal with black. what you are mainly looking for is the feel of it when you flex and how sturdy it may feel. obviously the metal would feel a lot sturdier than the rubber/plastic kind.
  15. #15 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    GM set
    Buffalo
    ^ so zzp must buy/sell the GM set
  17. #17 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
  18. #18 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    I used the plastic own ones just recently b4 I knew about the metal ones. How long do u think thes plastic ones will last?
  19. #19 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Nov 2010
    Illinois
    ull get a few years out of em. maybe 50 to 80k miles. if u left the dex cool in there it seems to tear the gaskets up a little bit faster. the good ol green stuff doesnt hurt it as bad.
  20. #20 Re: How to tell if you have the GOOD Lower Intake Manifold gaskets.
    Jan 2012
    Philadelphia
    i just swapped the the green yesterday i flushed the system then replaced my coolant elbow. LIM gaskets are coming once im ready to do the Gen 5 swap
  1. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  2. Replies: 7
    Last Post: 12-25-2011, 08:02 PM
  3. Changed lower intake manifold gasket and valve cover gaskets
    By grn97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2011, 08:19 PM
  4. Lower Intake Gaskets
    By predracer04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2011, 03:25 PM
  5. Intake manifold and VC gaskets...
    By bowsox88 in forum General Tech Discussion
    Last Post: 02-15-2011, 07:52 PM
