Thread: How to Properly Paint/Refinish your Rims
Results 1 to 20 of 56
  1. #1 Re: How to Properly Paint/Refinish your Rims
    Jan 2012
    Philadelphia
    if you went through the clear while sanding you will want to sand down the rim with anywhere from 1000-1500grit wet IMO because you want the clear to stick (scuffing will work with a red scuff pad also) scuffing will help eliminate the risk of blowing through base coat.
    if you are going to clearcoat them don't polish them because you want to eliminate as much contaminate off the rim as possible the clear will make them shine don't worry!
    also my thoughts on painting with a rattle can for clear on rims.. its okay for some things i would recommend it however if you use ones they sell for rims that might work a lil better its defiantly worth a shot you will save money doing them yourself! but the clear i recommend if your doing it with a rattle can is jam clear/edging clear it is automotive clearcoat in a can and it can be found at a automotive/collision supplier.
    if you need more help or other questions let me know
    and thanks for the compliment
  2. #2 Re: How to Properly Paint/Refinish your Rims
    SE Level Member Burley117's Avatar
    Nov 2011
    Kalamazoo, MI
    Awesome, thank! Good to know about the polishing too....for now the plan is to finish sanding down the rest of the clear and re-clear them. I take it that applying clear coat can be done in the same way with 2-3 coats and 5-10 minutes flash between them?
    06 Grand Prix, 01 Grand Prix GT, 98 Grand Prix GT, 98 GrandPrix GTP
  1. How to properly refinish a set of roof rails
    By gtpeddie in forum How To Write-Ups/Tech Tips
    Last Post: 03-23-2012, 11:42 PM
  2. Investing properly
    Last Post: 08-11-2011, 03:52 PM
  3. sunroof not working properly
    By BoostnBlackGTP in forum General Tech Discussion
    Last Post: 02-20-2011, 06:39 PM
  4. Heater not working properly
    By dms13 in forum General Tech Discussion
    Last Post: 12-13-2010, 07:16 AM
