Thread: How To Install ARP Head Bolts by Farnsworth
Page 1 of 3 123 LastLast
Results 1 to 20 of 48
  1. #1 How To Install ARP Head Bolts by Farnsworth
    Oklahoma
    They way I do it, with great results.
    Make sure the block is clean. The top of the deck is clean and smooth, and all the old head gasket is removed.
    I suggest that the head stud holes be cleaned out well with a tap, cause all your doing is chasing the threads, and cleaning out the old GM thread sealant, your not cutting new threads.
    Once that is done, you clean the holes again with a pipe brush and brake cleaner.
    You then use Teflon Paste that has a very good heat range, I believe what I use is in the range of -30*F to 500*F. You want to put some on a screw driver, and apply it down in the holes of the block. You also want to apply a good amount to the studs them selfs, so thick you pretty much pack the threads full so its smooth all the way around, up and down of the lower threads with the paste.
    You then hand start them into the block, and run them in all the way and pre torque them in with 10 lbs. ft. This does nothing more than make sure they are fully seated in the block. If your doing it by hand...you will never get them to bottom out.
    install the head gasket...I have installed the MLS 3 layer ones dry and never had a problem. I have reused them so far 3 times with copper spray and no leaks...so do what you like. If you do install them with copper spray, give the gaskets a quick wipe down with some rubbing alcohol and hang them from a hook, and spray on several light coats of the copper spray till its evenly covered, DO NOT GET ANY RUNS when your painting them. Thats bad!
    Install the head gaskets on the prepped block.
    On the tops of the studs, where the head stud nuts are, I will apply some of the supplied molly lube to the threads.
    I will then install my prepped heads.
    I will then take the supplied ARP washers, and coat BOTH sides of them with the supplied molly lube.
    I will then take the nuts for the studs, and apply the supplied molly lube to the BOTTOM of the nut that will make contact with the washer, and I also add in some to the inside threads of each nut.
    Torque procedure I follow is 40, 60, 80, 90, and then check again later with a follow up 90 lbs. ft.
    The pattern which you follow is
    5136
    7428
    1,2,3,4,5,6,7,8 in that order when you look at the head from above.
    Pretty much you start at 40lbs ft. and slowly bring the torque up so that the head is being pushed down slowly. Your final number is 90.
    ARP says 70 lbs. ft for ARP Molly lube and 85 with 30 wt. motor oil, do not follow this, as this is not specific to your cars 100%.
    When I will install heads...I will pull the motor so i can work around the motor fully so I do the job right the first time. You can do the work with the engine still in the car, and do a good job, but this is what I prefer to do if I am doing the work myself.
    Copy, and save this for your records if you want to follow this method, I don't know how many times I have typed this up for others. LOL
    Enjoy.
    ~F~
  2. #2 Re: How To Install ARP Head Bolts by Farnsworth
    Wichita, KS
    Should STRESS the importance of getting the correct heat range of the paste!
    Some have bought it, and did not read the specks of it before using it only to have the job done, and have coolant leaking up around the studs after the engine gets to operating temperatures.
    In this case, you will have to completely clean out all that paste that was installed well, and redo each stud with the correct heat range of the paste.
    Teflon Tape is not recommended
    , and should not be used for a ENGINE applications such as this.
    ~F~
  3. #3 Re: How To Install ARP Head Bolts by Farnsworth
    TDCRacing
    Guest
    Quote Originally Posted by GR8racingfool View Post
    ~F~
    Care to explain why it is ok to use teflon paste but not teflon tape?
  4. #4 Re: How To Install ARP Head Bolts by Farnsworth
    Wichita, KS
    Seen the tape over hang break loose, and get circulated around the system, and eventually create a clog in the radiator restricting flow.
    If installed/wrapped correctly, you "could use it" its not rocket science to use tape, but for my assemblies, and builds, I use what I know for sure works, cause I don't like repeat customers for something I did or did not prevent.
    With paste...seems like it would be more prone to breaking off in a chunk, and doing the same as far as creating a clog, but I have yet to see this on any engines I have ever built, or worked on.
    Thread seal tape - Wikipedia, the free encyclopedia
    ~F~
  5. #5 Re: How To Install ARP Head Bolts by Farnsworth
    TDCRacing
    Guest
    What about High temp RTV? Same issues?
  6. #6 Re: How To Install ARP Head Bolts by Farnsworth
    Wichita, KS
    High Temp RTV for head bolts? !?!?!?
    ~F~
  7. #7 Re: How To Install ARP Head Bolts by Farnsworth
    TDCRacing
    Guest
    ~F~
    Sure, heard of lot's of people using it with sucess. I don't see why it would do any different of a job than Liquid or tape thread sealant. Do you? I mean it's still sealing the threads and the temp range of it is more than enough.It also is a lot more durable than thread sealant in the fact of it ''breaking off and getting circulated through the system'' That is what I was kind of getting at with my question. It Seems if to much liquid thread sealant was applied it would do the same as you described the tape would. Wich is ''break off and circulate through the system''.
  8. #8 Re: How To Install ARP Head Bolts by Farnsworth
    Oklahoma
    Im kinda curious about this myself now.
  9. #9 Re: How To Install ARP Head Bolts by Farnsworth
    Moore, Oklahoma
    I've heard of people using High Temp RTV, specifically the Ultra Copper (high heat) stuff from Pemertex. I donno i'd use it personally though, with my luck i'd get screwed. Then again I don't see how it would not work and last for years. I donno...
    Shawn W. Larsen
  10. #10 Re: How To Install ARP Head Bolts by Farnsworth
    TDCRacing
    Guest
    Used some High temp RTV on the installation and has been working fine. And I have not seen why it would not in the first place.
    Figured I'd let you guy's know that you now have another alternative to sealing up those head bolts. And quite possibly the best alternative out there.
  11. #11 Re: How To Install ARP Head Bolts by Farnsworth
    GT Level Member tylerbinski's Avatar
    Canada
    Great info, thanks Farnsworth.. I have the ARP studs and the following sealants... which is best to use ? Thanks
    OR
  12. #12 Re: How To Install ARP Head Bolts by Farnsworth
    TDCRacing
    Guest
    You can use this... It's tested and proven.
  13. #13 Re: How To Install ARP Head Bolts by Farnsworth
    Canada
    I also have GM Gasket Maker, I'll check to see if it is high temp.
    Thx
  14. #14 Re: How To Install ARP Head Bolts by Farnsworth
    Bastard Reptile's Avatar
    Kansas City, MO
    GM Gasket maker is something completely different. You do not want to use it for this application. It's actually an anaerobic sealer.
  15. #15 Re: How To Install ARP Head Bolts by Farnsworth
    Canada
    I ended up using this one.
  16. #16 Re: How To Install ARP Head Bolts by Farnsworth
    SE Level Member thomasj's Avatar
    Indiana
    There is nothing wrong with using RTV on head studs. I previously raced mustangs before I started playing with these cars. EVERYBODY used RTV on their head studs. It was the norm. Doesnt really matter what color. If your engine gets hot enough to affect any of the RTVs your screwed anyway Standard RTV is good up to 500 deg.
  17. #17 Re: How To Install ARP Head Bolts by Farnsworth
    Wichita, KS
    This:
    is what GM calls for during a rebuild.
    Kinda pricey, so that's where my suggestion comes into play for a good solid alternative.
    Use what you want to, I merely did the step by step write up cause many were using the molly lube on both ends of the bolts and wondering why they were leaking.
    Also, some were using Teflon paste, that was only rated up to 100 some degrees, for your common house hold plumbing repairs. Your engine operates a little hotter than that...so once it reaches that temp. the Paste turns soft again, and allows leak by. Then you have coolant leaking out side the engine, as well as in.
    Just saving people headaches, Heads are one job I prefer to do right the first time was my whole reasoning behind it.
    ~F~
  18. #18 Re: How To Install ARP Head Bolts by Farnsworth
    Canada
    BUMP
    totally stuck tryng to decide to use teflon paste or teflon tape
    ZZP says tape
    Farns or Gr8racing says no tape, teflon paste, permatex high temp thread sealant.
    well.. can we have a vote here?
    I used GM Teflon Pipe/Thread sealant with PTE last time and loaded it on the threads.. but i suspect they were leaking so i am removing all head studs and want to do them over again.
    i think i am going to use tape this time.
    '04 BLK GP - .. Turbo :P
    GTP SIC - '02GTP | XP Cam | Intercooled Turbo Kit | Cutout....Fire mod 9/11
    GTPSIC '02 | Twin charge, XP cam et
  19. #19 Re: How To Install ARP Head Bolts by Farnsworth
    use paste, not tape. let it dry for a while too, dont just put it all back together right away.
  20. #20 Re: How To Install ARP Head Bolts by Farnsworth
    Donating Users
    GRAND RAPIDS, MI
    How long would you say to let the paste cure?
    2000 Grand Prix SE: Knocking rod mod and broken timing chain mod. L67 coming soon!
  1. ARP Header bolts
    By Sabrewings in forum General Tech Discussion
    Last Post: 07-29-2008, 01:57 PM
  2. S/C Bolts ?
    By Meemperor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2008, 03:18 PM
  3. ATTN Farnsworth - tool info needed
    By IndeedSS in forum General Tech Discussion
    Last Post: 03-14-2008, 10:54 AM
  4. camber bolts
    By nemesis in forum General Tech Discussion
    Last Post: 02-29-2008, 05:10 PM
