bloaty57
Bill.....I have the 00' L36 and I replaced the uim without the stovepipe because I read where that year was of a smaller diameter......but from what you mentioned, replacing the stock one with the stovepipe doesn't make a hell of a lot of difference anyway. I also read what Rico said about it being a pain to pull or change out the stock tube. I'd almost think that you'd have to cross drill the tube and use a puller of some sort so you didn't have to kill yourself getting it out. The only other option I thought of was putting the narrow stovepipe in then wrapping it with a thin layer of that white heat fiber wrap they use in high heat applications. It will take direct heat from a torch and not even discolor.
Regardless....I have hex type (drive) aluminum threaded plugs in the shop and I think they'd fit flush, but unless I missed something, would there be any issues with the throttle body and/or it throwing codes ?
