Thread: Upper Motor Bracket
Results 1 to 3 of 3
Threaded View
  1. #1 Upper Motor Bracket
    GT Level Member SoergBot's Avatar
    Oct 2011
    Dayton
    My first write-up, hope it helps some out there with the same problem.
    So recently my Upper Motor bracket broke on me. This was a mistake on my end actually,
    after the headers went on somehow the bracket that bolts in there forgot to find it's way back on.
    So this was the outcome of course, which I hear this is the bracket that causes the most trouble
    So after calling around, the best I could find was 86.00 including two-day shipping on the bracket.
    The next morning my dad and I took a trip up to the junkyard to see if maybe there was
    a bracket lying around for us to salvage. Apparently there were none, go figure. So we
    started looking on some older Buick's and other cars with a decent sized motor.
    Anything that would hopefully match up to what the old bracket was. This is what we found.
    25.00 dollars later and we brought it home, and it seemed to match up pretty well.
    It matches up better by the dipstick than it looks, i will get a better pictures after grinding is done.
    Everything except for a small notch on the back, which a little grinding will fix.
    I am in progress of working on this right now, so it will be done hopefully in the next few hours or so.
    Have a doctors appointment in the meantime, but i wanted to get it posted before my laptop dies.
    *****************an hour or two later*********************************************
    So bare with me on this one, this is still a how-to thread, but it may be different for everyone
    After looking we decided to loose the bottom half and cut the tab off of the one side.
    Currently my father is welding in the new tab and pictures will come as we complete the journey
    But this is what the piece looks like so far
    AND THE FINAL PRODUCT!!!!
    MOUNTED!!!
    I will explain later, gonna go eat
  1. Cracked upper motor mount bracket
    By vailskier3 in forum 04+ Specifics
    Last Post: 04-16-2012, 02:11 PM
  2. Installing upper poly motor mounts?
    By Smokin2000gtp in forum General Tech Discussion
    Last Post: 10-12-2010, 11:10 PM
  3. upper motor mount help please
    By Red_GTP in forum Brakes/Suspension/Chassis
    Last Post: 08-03-2008, 01:28 PM
