Thread: Heater hose adapter fitting part #'s and information.....
Results 1 to 4 of 4
  1. #1 Heater hose adapter fitting part #'s and information.....
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    I spent well over 2 hours on the internet trying to find the part #'s for the metal adapters that slip into the heater hose and go into the alternator bracket.
    If you guys don't know what I'm talking about, here's a picture, the pieces that I am referencing are circled in red:
    97-98 alternator bracket (with cast metal lower coolant elbow)
    99+ alternator bracket (with plastic lower coolant elbow)
    These adapters rarely look re-usable when swapping coolant lines. They are usually corroded with dex-crap and just plain nasty. As you can see the 97-98 are slightly different than the 99+ when it comes to the bracket. Pay close attention to which ones you need!!!
    Here are the dealer part #'s for replacement adapters (the come with the o-ring already installed on them)
    97-98 heater hose adapter - PN # 24506012
    99+ heater hose adapter - PN # 24506322
    For all your 3800 needs:
  2. #2 Re: Heater hose adapter fitting part #'s and information.....
    Arlington, VA
    man this was a life saver...thanks for post copgtp.
    I can find the part at gmpartsdirect, but was hoping to find it at a local autozone or advanced auto....any suggestions?
  3. #3 Re: Heater hose adapter fitting part #'s and information.....
    Drive to a JY with a razor knife, pair of pliers and 8mm shallow socket. Look for any GM of the era and you'll have those fittings in minutes.
    Remove 8mm holding the piece to the alt bracket
    Cut hose
    Use pliers to wiggle piece out
  4. #4 Re: Heater hose adapter fitting part #'s and information.....
    Arlington, VA
    Done and done, thats exactly what I did...cleaned them up with some break cleaner and wire brush, put new o-rings on and they are good as new. Cost next to nothing.
  1. Tranny thread fitting Information
    By UR LOSN in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-15-2017, 03:36 PM
  2. Heater hose bypass fitting.
    By Peirce1970 in forum General Tech Discussion
    Last Post: 01-30-2012, 03:35 PM
  3. Heater core - which hose?
    By Skrappi69 in forum General Tech Discussion
    Last Post: 04-06-2011, 12:53 PM
  4. Which is the hose the goes to heater core?
    By DesertFox in forum General Tech Discussion
    Last Post: 05-16-2009, 06:08 PM
  5. Fitting Part Numbers?
    By Scimmia in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2009, 09:47 AM
