Thread: 3.1 mpfi to dohc 3.4 swap
Results 1 to 20 of 46
  1. #1 Re: 3.1 mpfi to dohc 3.4 swap
    GT Level Member 91gpse's Avatar
    warren, mi
    Ok guys.... You ready? Time to start the swap. I have everything unbolted except for the downpipe bolts but I can still explain the process to pulling it out. These basic steps work for any fwd gm swap.
    Step 1. Remove battery and fluids.
    Step 2. Disconnect wiring harness at all points to the body.
    Step 3. Jack up front end and remove the front tires.
    Step 4. Pull calipers,caliper mounting brackets and rotors off.
    Step 5. Unbolt hubs and pop out halfshafts from trans and remove assembly.
    Step 6. Unbolt exhaust pipe from manifold.
    Step 7. Remove plastic dust cover on drivers side covering the trans mount.
    Step 8. Unbolt the drivers side trans mount(as shown).
    Step 9. Remove plastic dust cover on passangers side
    Step 10. Unbolt passanger trans mount(from bottom of k frame easier access)
    Step 11. Hook your hoist as shown to the factory assembly crane brackets.
    Step 12. Hoist it up and out.
    And the engines out.... My next post should be of the install.
  1. [10-09-2013 ] 3800 swap&topswap Complete!
    By Z34Phoenix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-09-2013, 01:55 PM
  2. 1989 grand prix 2 door 2.8 mpfi digital dash
    By mikedinthecity in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-26-2010, 03:26 PM
  3. 3.4 dohc
    By 67GTO in forum General Tech Discussion
    Last Post: 06-11-2010, 06:36 AM
  4. 3100 sfi swap to 3.4l Dohc
    By Wigsos in forum 3.4L V6 (LQ1) DOHC
    Last Post: 05-27-2010, 03:04 PM
  5. Engine swap - 96' 3.4l DOHC out, '93 3.4l DOHC
    By csbrown in forum 3.4L V6 (LQ1) DOHC
    Last Post: 11-11-2009, 04:47 PM
