Z34Phoenix
Ok coming from someone who had a DOHC for many many years... i ask too why? i know you said to be different, but your goal with that amount of HP is not easy at all. i probably had the most HP Na from one of these DOHC and it wasnt easy. further more, the trany just will not hold the power.
there are no mods left out there for this engine. i sold recently an under drive pulley and my ported intake manifolds.
what i can recommend to get the most out of it are the following:
-swap to a 96+ style intake manifold set (lower, upper, arm, and tb)
-port the lower to the heads, Upper to arm, arm to TB, and port the TB.
-Underdrive pulley if you can find one.
-get a chip from 60degreev6.com
-port heads?
-look into custom cams?
-have custom headers made?
and with all that it will still be hard for the goal you set
